1vj-3aj gear sets the same?
Posted: Sat Jul 07, 2012 9:16 pm
by jibber
as the title really, apart from the output shaft sprocket retaining differences are the gear sets the same?
Re: 1vj-3aj gear sets the same?
Posted: Sun Jul 08, 2012 10:12 am
by bopster
Looks to be the same part numbers apart from the prefix ie 2RW-17411-00 on the 3AJ is 34L-17411-00 on the 1VJ (item 1 on the parts list
main axle).........item 15 (circlip) is the only difference I can see it's 93440-25019-00 on the 3AJ and 93440-25084 on the 1VJ.........may be just
stronger on the 3AJ?............bopster
Posted: Sun Jul 08, 2012 7:28 pm
by jibber
cheers bopster
Posted: Sun Aug 26, 2012 4:58 pm
by dunc
No doubt someone will be along to correct me but to the best of my knowledge the 1VJ and 3AJ engines are the same. The only parts I have noticed labelled 3AJ are the right engine casing where the serial number is and the oil pump.
Posted: Sat Sep 01, 2012 2:39 am
by scottieh
dunc wrote:No doubt someone will be along to correct me but to the best of my knowledge the 1VJ and 3AJ engines are the same. The only parts I have noticed labelled 3AJ are the right engine casing where the serial number is and the oil pump.
I think the fins on the heads of the 3AJ are a little different to promote better cooling to resolve issues of overheating that plagued the 1VJ. I think the heads are interchangeable but the 3AJ is the superior part.
