Any suggestion where I can find a replacement pick-up coil for my '83 34L?
I've had significant hot engine cut-out issues and left stranded a number of times. Typically have to wait 10-45 minutes before she fires up again.
Had the stator re-wired which improved performance but did not solve the problem entirely.
For good measure I also replaced the CDI with a Wieltronic one, but that wasn't the issue either
http://www.ebay.com/itm/330928074321?it ... m=&vxp=mtr
Seems the pick-up coil remains the rotten apple to be replaced, but can't find one without buying complete stator assembly (expensive!).
Saw someone customising a pickup coil for a 1982 XT550 from two aftermarket coils with similar resistance here:
https://thumpertalk.com/forums/topic/11 ... omLogout=1
The resistance specs and 12, 36 deg advance for the XT550 appear similar to my 34L's (110 Ohms +/- 18%) and thought I should give this a try should no coil materialise.
Anyone tried something similar?
All advice appreciated
