Wondering what i'm missing with the Tach Drive assembly.
I am wanting to replace oil seal #25 shown in the diagram.
I have removed the worm gear/shaft that engages with the output shaft to the tach cable however this tach cable output shaft will not pull out along with the seal #25 on top of it. I see no retaining clip etc and assume it should just pull straight out, I've tried with needle nose vice grips to pull it out but it doesn't budge
