I wanted to get a bit of advice from those who know these bikes better than I do — just to make sure I’m starting off on the right foot with the initial overhaul.
Before attempting to start it, I was planning to go through the following:
• Engine oil and filter
• Full carb rebuild
• Clean and possibly seal the fuel tank
• New battery
• Bleed brakes front and rear
• Check all wiring and connections
• New spark plugs
Is there anything else you’d recommend tackling early on — either common problem areas on these or general good practice before firing it up for the first time?
Thanks in advance for any pointers,
Ollie
