Acerbis plastic tank decal
drumnagorrach
What Bike or Bikes Do You Own?: Ducati S2R 1000
Previously Owned Bikes: Guzzi T3 Cali ,Cali 3 and Sport 1100. BMW R100/7 and R90S. Various Triumphs ( Meridan) .
Lots of Yamaha DT's 175-400,Suzuki PE 250, and SP370.And a very early XT500 ,it's engine no's had three zero's in front of the last three no's ( can't remember what they were ).
Post by drumnagorrach »
Can anyone recommend a tank decal for the acerbis 23 litre plastic tank ? It hasn’t got a smooth surface so I wonder if anyone has managed to get a Yamaha decal to stick to and stay stuck to it .
Missinglink
What Bike or Bikes Do You Own?: Tenere 55W .... T7 and too many others
Re: Acerbis plastic tank decal
Post by Missinglink »
What like this....
drumnagorrach
Well just a simple Yamaha would do . Is that an acerbis plastic tank ?
Missinglink
Yes fella....
drumnagorrach
Fine , what sort of decals did you buy ? This is like pulling teeth 🤪
Missinglink
It's nothing special, just a standard graphic, the surface of your tank sounds suspect.... if it's rough or pourous then you'll be on to a hiding to nothing.
drumnagorrach
My tank is new , and I wonder if there is a mould release agent on the tank . I tried a couple of vinyl decals and they didn’t stick .I cleaned the area of the tank with cellulose thinners prior to attempting to stick the decals to no avail .
Anyone fitted vinyl decals to an Acerbis plastic tank ?
Some plastics don’t like adhesives very much. Clarke brand motorcycle tanks in the USA are made of a roto molded plastic that will not chemically bond to adhesives, glues, or paints so stickers just fall right off, paint peels, and plastic and epoxy repair patch kits for damages are useless.
I don’t know what the formula for Acerbis plastic tanks is but it might be using a similar plastic.
Scumfrog
59x
43F
Post by Scumfrog »
I didn't have any problems. However this tank has had a lot of work to get it to this condition, I.e. scraping and sanding.
Could cellulose leave a residue on plastic? I use isopropyl alcohol.
