Oil leak top of engine case
Posted: Wed Aug 17, 2022 6:35 pm
by Reubodad
I have an oil leak under the starter motor...
I am sure its from the connector of the oil pipe to crankcase.... I have put in a new seal but still leaking... What is the best thing to put on the connection????
Help!!!!!
Cheers..
Re: Oil leak top of engine case
Posted: Wed Aug 17, 2022 10:28 pm
by Reubodad
And so!!!!.. Searching around a bit I find out about the extra 6mm bolt that's inside the starter motor casing..... It was missing.. And yes I didnt replace it as I should have.... However the spare motor also had it missing too..
So its replace it in the morning and hopefully no more leaking!.. 🤞🤞🤞
Posted: Thu Aug 18, 2022 5:43 am
by jibber
:congrats:
