Finally my long waited 1VJ arrived after 2 months of searching and waiting for it to arrive in Estonia. Now I luckily got my hands full for the winter with various mechanical and cosmetical jobs :)
The previous owner told me that the regulator/Rectifier was faulty, and it was well confirmed by the diode/continuity test + by the fact that the voltage didn't increase withi increasing the RPM's.
He also included a new regulator with the bike and the diode/continuity test showed that the unit was all good. Once installed on the bike the it seemed to be charging the bike as well.
Yesterday after cleaning the carbs i decided to check the voltage on the battery and it seemed that it had run dry over the course of few days. I charged the battery and checked the current between the negative terminal and the wire supposed to go on there. It read about 0.19-0.36 AMPS, the reading didn't change at all when switching the ignition on/off with the key. Didn't have too much time at that point to go over all electrical connections, but i noticed that the current went to "0" when i disconnected either the main fuse(Red wire coming from the starter switch assy) or disconnecting the regulator/rectifier. Not sure if relevant information, but i still heard the "click" coming from one of the relays when switching the ignition "On".
Has anyone encountered a similiar issue before? Seems to me that either the Regulator/Rectfier or the steering lock switch is busted. Not too familiar with the electrics of the bike yet, but 0.19-0-36 AMPS seems like an awful lot of current going through when the ignition is switched off.
Thanks for the help and a picture of the bike as a bonus!
