Hello Peeps,
I've had a few issues with my 43F!
It's a bitch to start when it's hot. Checked the spark plug and its covered in black soot so it's running rich which could be the cause of the no hot start. I've checked out the choke plunger to see if its leaking but it seems to be in good nick. I'm quite confused about changing the fuel / air mixture. Do I need to remove the carb and unscrew the actual jet?
Also, got a serious knocking from the engine. It happens when I throttle off at high revs under load. I suspect it's the big end bearing but before I tear down the engine, I thought I'd try adjusting the valves and check that the timing was working OK. Does anybody have any other checks I can make before committing to busting open the engine?
All help is gratefully received as always.
Si.
Black Spark Plug
MentalScientist
- What Bike or Bikes Do You Own?: 1986 XT600 - project
1980 DT250 - restored previous project
2001 ZX9r - runaround bike
zzr600 - next custom project
Triton - future project - Previously Owned Bikes: many
Re: Black Spark Plug
