I´m new at this forum (recently purchased a 1987 1VJ Tenere 600) and thought maybe you could help me out with this one
Soooo...here´s the thing, the front headlight and some light indicators stopped working as I changed the tachometer for a functioning one, so that I tried to replace the bulb (didn´t work out) and then tried with the old tachometer again (didn´t work out either). I then checked the wiring diagram and found a wire that was connecting all the stuff that started malfunctioning. I was quite sure that while replacing the tachometer I could have cracked one of the old headlight connector wires/pins so I decided to pinch for continuity all the wires at the headlight and discovered that I my thoughts were right and that the headlight connector with the 3 headlight-bulb connections had some stuff going on. 2 of the 4 wires where cracked/broken at the very top, one of the connectors was stuck inside the plastic-plug, which resulted to be melted-stuck at that connection...
So I´m now looking for a replacement plastic-plug but can´t find one, does anybody have had this same Issue? Where do you ussually buy the electrical spares? Any alternative?? The rest of the things I need, like new connectors or spare wire is easy to find on internet so don´t care that much about that.
My english isn´t that good, so I´ll post 3 pics at the end to help me explain it. I also will be posting some photos of my own tenere
Deceased plug on the side of the wiring connectors.
Plug on the side of the headlight-bulb.
The 3 connectors with the 4 wires (the one connector on the left has the melt of the plug)
Cheers,
Ibai.
