tenere 1VJ correct coil location
Posted: Sun Apr 28, 2019 9:42 pm
by cadno
hi, anybody got a photo of where the coil should sit on the frame. Bought a basket case without one soI bought an aftermarket one from Brooks barn and I'm not sure it's correct.
Any info much appreciated
Re: tenere 1VJ correct coil location
Posted: Sun Apr 28, 2019 9:55 pm
by charliext1vj
http://members.chello.nl/h.hoorn6/yamah ... re_1vj.htm
similar to how I have mine - but I wrap it past the main frame to reduce the heat
Posted: Sun Apr 28, 2019 10:26 pm
by cadno
thanks, give us a clue, where's the coil mount photo?
Posted: Mon Apr 29, 2019 6:04 am
by motorang
Follow the ignition cable, there it is, front downtube left hand side
Posted: Mon Apr 29, 2019 5:20 pm
by cadno
Brilliant thanks Andy
Posted: Mon Apr 29, 2019 5:30 pm
by cadno
The coil I've bought has a two bolt mount that doesn't seem to match any mounting on the frame.
Is the coil rubber mounted as my frame has a tang for a rubber in that location very similar to the battery box relay mount tangs.
Posted: Mon Apr 29, 2019 6:13 pm
by charliext1vj
have you found your answer - send a picture of it - not sure which one you have so far doesn't sound like early xt600.
Posted: Mon Apr 29, 2019 6:56 pm
by motorang
It sits on a tang:
Check the exploded view
https://www.cmsnl.com/yamaha-xt600z-198 ... Mc5k4rgrCM
> Electrical 1
And there is a damper by the parts number 1VJ-82317-00
Posted: Mon Apr 29, 2019 7:54 pm
by charliext1vj
mine in situ
Posted: Tue Apr 30, 2019 4:08 pm
by BMurr
cadno wrote: Mon Apr 29, 2019 5:30 pm The coil I've bought has a two bolt mount that doesn't seem to match any mounting on the frame.
Sounds like you have the wrong coil, you have the one that has a bar going through the coil with bolt holes on either end. EBay listing have wrong coils listed in some instances but you can tell by the pictures shown on this thread as to whether you have right coil or not.
