1VJ Clutch Setup
Posted: Sat Feb 16, 2019 6:13 pm
by Muppdog
Hi, been a long time since I needed some help.
A long, long time ago I fitted new clutch plates when I reassembled the engine on my 1VJ. I followed the Klymer and a German manual . Both asked for the pointer on the clutch actuation lever to line up with the mark on the crank case. Pictures in both not clear at all. Problem is, No Mark on the crank case but two pointers on the lever. Back then I just winged it, pushed the lever forward to line up with the cable exit and assembled the rest. Worked, but not well. The clutch bites too late.
I now got an actual 1VJ clutch cover which I am going to fit. While I am in there I want to adjust the clutch properly. So, where is the illusive mark on the case? And which pointer is the right one? I am ok with the rest of the process.
Re: 1VJ Clutch Setup
Posted: Sat Feb 16, 2019 6:41 pm
by cadno
weirdly, I'm putting the engine back together in mine.
I was missing the washer behind the shift actuator but it came today. So I'll be putting the clutch side back together this evening.
I had noticed the two markers on the clutch arm, mine has a fairly distinct mark on the crankcase, but the outer cover is away at the sprayers.
I'll have a play later and try and get my head around the two pointers
Posted: Sun Feb 17, 2019 11:16 pm
by Muppdog
Thank matey. Where abouts is that mark on your crank case? In relation to the lever. Or oil pipe.
Posted: Tue Feb 19, 2019 8:05 pm
by cadno
PM me your email and I can send a photo
Posted: Fri Feb 22, 2019 11:06 am
by motorang
The lever setting is correct when there is a right angle between lever and cable at the point where the clutch is actuated.
I can have a look and maybe take a picture in the evening.
Posted: Fri Feb 22, 2019 11:29 am
by motorang
Found a picture in an original Yamaha workshop manual (XT600E 1986-90) and made a picture of it ...
XT600E_clutch
by
Andreas G, on Flickr
Not sure if it is the same with the 1VJ
Posted: Sat Feb 23, 2019 12:15 pm
by motorang
OK, so I made a picture. Please note that my 1VJ has the electric leg removed, so this may be much harder with the electric motor hiding the clutch lever.
Also note that the clutch lever is perpendicular to the cable, when the marks are aligned ...
The 1VJ lever has the same little indicator as the XT600E lever in my earlier post, plus a bigger one to align with the 1VJ engine case indicator, so I think this is one lever to fit several models.
All the best
Posted: Sun Feb 24, 2019 4:46 pm
by Muppdog
Thanks Guys,
Sorry for not replying sooner. Not a total git, yet. My tablet I am travelling with only gave me 'fatal error' messages when tapping the reply button. But here I am, and grateful.
Looking at the pictures and reading your discriptions my setup was pretty much OK. I aimed for the cable to be at 90 deg with the lever. Still was not happy with the clutch action.
Will let you know how I get on after redoing the set up. Still traveling atm.
Btw, can't recall seeing that mark. Does not mean it's not there, though.
Rob
