Wiring runs 3YF
Posted: Fri Apr 28, 2017 10:13 am
I'm just going through the wiring on my 3YF, having watched the regulator fail the first time I got it running since I bought it a few weeks ago.
A fair few evenings of corroded wire replacement and new connectors but it's coming together now. I hope the cooked stator connections don't mean that the stator has been damaged...I guess I can check that come to think of it.
and
The reason for the post is to ask whether anybody could show me a picture of the left hand side / top of a 3YF without tank/seat/ sidepanel off ( or link to existing) to determine the run of the the stator,neutral,ignition pick-up wires (as one set), the wires to the battery and the starter solenoid. So essentially which way around the vertical frame section from the top tube to the swingarm spindle.
Also how are the wires to the rear (cdi,lights etc) positioned.
I can, of course see what works but it would useful to know where it's supposed to run.
and also...is there a piece of plastic supposed to be between the back of the air box and the plastic tray upon which the cdi sits?
Many thanks,
Rich
and
Many thanks,
Rich
