Oh no I've taken it apart
bigiain
What Bike or Bikes Do You Own?: 55w tenere in bits Honda xr 650r
Previously Owned Bikes: Suzuki er 125, Yamaha rd 350(still got a sore knee from crashing it)
Bombardier 250, Honda xl 250, Honda xr 600,Suzuki Dr 600
Xt600, Yamaha fz 600, s10 750, Kawasaki zx9r,Honda cr 500
Yamaha yz 490, Kawasaki kx 500, Yamaha xt 500 ( sold it for £200 what a
Tosser)
Post by bigiain »
Took clutch out I held against it using actionmans rag trick! How do you hold against the centre bit to get the big nut off without breaking the fingers of the basket
The camshaft and rockers look ok to me
What are all these wee holes? The piston looks brand new
bigiain
Tosser)
Re: Oh no I've taken it apart
Post by bigiain »
How do I tell if it's a standard piston
The bore feels ok with no scores should I get it honed and fit new rings. What should I check while its apart how do you see 5th gear what about updated oil pump fuckin hell sorry that's enough questions!
Pitting is normally a sign of detonation, id like to have seen the old piston. :bigyikes:
May as well pop out the valves & check the seats, and fit a 3AJ oil pump 1988 & newer (don't limit your search to Tenere`s) all XT`s from 88 onwards all used the 3AJ pump.
kevingrahambutler
Post by kevingrahambutler »
"""""""""against it using actionmans rag trick! How do you hold against the centre bit to get the big nut off without breaking the fingers of the basket"""""""""""
Use a windy gun Brian
There's a proper tool to hold the basket while you undo the nut....
GeoffD wrote:There's a proper tool to hold the basket while you undo the nut....
I think Dave has one now? :scratch: i know Eric does, here it is.
bigiain
Tosser)
Post by bigiain »
FFS I'll never copy that! Will try and make up a more "agricultural" version.
Can I still use the head with the pitting, is it harmless?
Cheers Iain
Edit : Thanks Mezo have found it on eBay for £27
He who dies with the most tools......wins
Yep some guys fashion one out of an old clutch plate, but it will never feel as good as the real tool.
I don't think the pitting will affect anything, if it was detonation (pre ignition) it may have pitted the valve`s face also? possible.
Googled the part no. on your piston, looks like you have a wiseco forged piston.
The 09700 part of the number is the bore, 97mm, so it's had a +2mm rebore.
Your next question should be why was it detonating (pinking)?
It might be worth checking the squish clearance (the distance between the top of the piston & the cylinder head) when you rebuild it.
Those marks are not from detonation.
They are from a foreign object bouncing up and down at 5000 rpm. Could be a small screw or something.
Would have also damaged the piston, hence the new Wiseco and rebore.
