Looking[drooling]at various photos of early 80's Tenere's some riders have the rear brake up facing up, some facing down. Anyone know why that is, and what is best? Is it just to avoid trail damage by facing it up?
REAR BRAKE SETUP
- wmoncrieff
- What Bike or Bikes Do You Own?: 1983 XT600 TENERE in sad condition! 1987 JDM VT250F [sold]
- Previously Owned Bikes: Last count, about thirty...........
REAR BRAKE SETUP
G'day All,
Cheers Will.
Re: REAR BRAKE SETUP
I think so Sherlock
I've not asked the question myself but i figured the same as you, hey that makes two Sherlocks.
- wmoncrieff
Hmmm. When I saved the RD from the wreckers it too had a rear drum with actuated by a rod linkage, and depending how it was adjusted had a big impact on the brakes sensitivity, with the brake arm parallel to the rod facing forward or back. Curiouser and curiouser...................Mezo wrote:I think so Sherlock![]()
I've not asked the question myself but i figured the same as you, hey that makes two Sherlocks.![]()
Cheers Will.
Its the same cam operating no matter which way you pull it, bit like your cock.
Mez.
Mez.
- wmoncrieff
Shit, I can't even tell if my rear brake works
At least there is less to go wrong than with the front disc
Cheers Will.
55W1985
I have put my rear break facing up.Of course it prevents breaking that aluminum part that way.
BUT you need to bent that rod a bit in order to avoid to hit the foot peg holder when suspension is down.
XR650L(1994) 55W (1985)
- wmoncrieff
