What has me foxed is on the main pivot - specifically parts #7 and #49. Now the diagram shows #7 between the swing arm and the rubber grommet #6 that fits inside the end cap #5
If I fit it up in this order the end cap and grommet don't fit on the end of the swing arm at all - the washer blocks them. To me it makes more sense that #7 fits inside the end cap and then the rubber grommet goes in - this them fits to the swing arm. Is the diagram wrong?
Finally what is #49? I don't seem to have that at all plus my chain roller seems to be way too loose between the flange on the swing arm and the frame - does #49 support the chain protector (#9)
Thanks!
