very long 3aj rebuild
Re: very long 3aj rebuild
Very tidy
gobo
- What Bike or Bikes Do You Own?: Yamaha Tenere 3AJ
BMW R1150GS
Romet Ogar 200 - Previously Owned Bikes: Yamaha Virago
Hello,
I'm having hard time bleeding the front brakes. I think, I've spent 5 hours last 3 days and cannot bleed those f... brakes
I pump the brake fluid with the master cylinder. It goes out down at brakes without air bubbles. I tried pushing the brake fluid from downwards with a syringe - the fluid goes out at the master cylinder.
I left the brake lever pushed in for two nights for any air bubbles to evacuate and still nothing.
I can feel it brakes but not enough. When the brake lever is pushed in I can move the front wheel with my hand.
I'm short of ideas ... If anyone has a tip or trick to do, don't hesitate.
Make sure the brake lever is not contacting anything that prevents full travel of the piston. Is the master cylinder the correct size for the new front end?
gobo
BMW R1150GS
thanks Eric, I checked the length of the lever travel - everything OK there. The master cylinder has the correct size - I've bought it as a set together with the brakes.Eric66 wrote:Make sure the brake lever is not contacting anything that prevents full travel of the piston. Is the master cylinder the correct size for the new front end?
I talked to a guy from a local motorcycle workshop. He advised me to try to install the rebuild kit for the master cylinder. He thinks the pump in the master cylinder may be used. As I don't have another option, I'll try that.
Regards,
Pawel
- King of Posting
I think Eric means look at the piston where it contacts the lever.
Sometimes the piston hits the switch cluster, preventing it from returning properly (move the brake lever bracket away from the throttle or twist the throttle assembly or brake lever to give more clearance)
gobo
BMW R1150GS
just to update on my brake bleeding problem : I tried everything 2 moths ago with no success. I left the bike for 2 months, I tried the brakes yesterday and everything worked well - I have very sharp brakes now
I've read that one needed a lot of patience and needed to let the nature do its work : the air bubbles would go up to the master cylinder with time. I suppose there are other, time effective methods, but at least my brakes are working.
I did some test rides today and the bike is feeling really well with the front from XTZ 750. And I am more confident when it comes down to breaking
Pawel
Pawel
BazzaB
- What Bike or Bikes Do You Own?: 2 x 1984 Tenere, 1 as a restoration project
The other is a hybrid XT/SRX/TT, Started life as a Tenere, TT suspension added then had an SRX600 electric start engine transplant
1988 XRV650 Africa Twin - Previously Owned Bikes: Several 1983 & 84 Tenere's
KLX 650
XJ600
DR250
XR350 - Location: NSW, Australia
Make sure you have no high points in your brake line after it leaves the master cylinder. Air rises to the highest point and can get trapped and hard to displace.
gobo
BMW R1150GS
some recent news : 2 years ago I've got an old exhaust manifold. I've thought about nickel plating it. I gave it to a guy that zinc plated all the nuts and bolts during my restoration and he told me that he would give it a try with nickel plating. After 1 year and a half he called me back that my exhaust manifold was ready. Given the low price of his services I didn't complain on the delays. Below is the result :
I have no idea how it will work in high temperature, with water splashing on it...
gobo
BMW R1150GS
mounted on the bike :
It's a bit late but the best way to bleed the brakes is to arm yourself with a large syringe and pump the fluid in from the bleed nipple on the caliper... works a treat & takes minutes rather than hours...
