Is "??????????" also a "breather/vent pipe"?
Where do I leave/put/mount the 'breather/vent pipes' hoses?
No, I did not mean the Neutral Light SwitchGeoffD wrote:Oil sensor? Don't you mean the neutral light switch?... Blue wire, that's probably why it'll only start with the clutch in
Looks like someone has lost the drain plug & fitted whatever they had with the right thread.Mezo wrote:Oil sensor?![]()
Well i've never seen one of them before?![]()
I was thinking the same thing, i have an oil tank with a temp sender fitted which makes more sense.xtzrick wrote:Why would you fit an oil sensor in a dry sump?
