I'll take pics tommorrow
Got a bit of a problem with no.5 ... stripping the engine today & found that one of the alloy nut things that hold the cylinder barrel on has corroded so badly that it's seized solid & not only that it's actually fused to the barrel itself.... I've seen these stupid nuts corroded before but this is the worst one I've come across.... tried undoing it today & the bolt head has snapped off.... it's gonna be a bastard to get off.....
That happened on my 900ss years ago, sheared itself off flush with the casing (nothing to grab hold of)
Ended up splitting the engine & milling it out.
Ouch, nasty problem.
I just took a look at a spare cylinder and the alloy nut.
You have 2 options as I see it....
1. Sacrifice the cylinder and two of the crankcase studs by using a thin 100mm cutoff wheel to slice through the lot.
2. Find someone with an EDM machine and make an annulus copper electrode and spark them out.
Good luck, our thoughts are with you.
I thought of a way last night, not sure it'll work yet
keny72
- Three to collect
- What Bike or Bikes Do You Own?: 1986 Honda VFR750Fx2, 1997 Honda Transalp 600, 1995 Honda SevenFifty, 2001 Kawa ZR7S, 1994 Kawa Zephyr 550, 1985 Yamaha FZ750
- Previously Owned Bikes: 2004 Suzuki DL650, 1990 Yamaha FZR600, 1986 Yamaha IT200S, 2006 WR250 Husky, 2010 Yamaha XT1200Z, 1984 Suzuki RG250W, 2000 Honda VFR800FI, 1991 Honda VFR750F, 1987 Honda VFR750F, 1985 Honda CBX750F, 1986 Honda VFR750F, 1987 Transalp 600,, 1992 Honda CBR600F, 1997 Kawasaki KLE500, 2001 Suzuki Bandit600S, 1987 Kawasaki GPZ500S, 1982 Suzuki GS500 Katana, 1990 Yamaha FJ1200, 1982 Yamaha RD125LC, 1983 Yamaha DT125LC, 1990&1989 Yamaha XT600Z Tenere, 1981 IT465, 1985 KTM125GS x3, 1987 KTM125GS, 1989 KTM250GS, 1996 KTM400SC, 1994 Kawasaki KX125, 1992 Kawasaki KDX200, 1996 Suzuki RM250, 2006 KTM250SX, 1995, 1997 & 2002 CR125R, 1996 CR250R, 1981 Suzuki PE175, 1989 Suzuki TS250X, 2011 BMW R1200GS, 2005 KTM EXC250 Racing, 2009 Yamaha XT125X, 1995 XRV750, 1990 CBR1000F, 2000 Yamaha TRX850
I had one of mine also corroded badly, but got it out By drilling the nut head to a shape of a bolt and then smach on a tool on it and got it turning. Was a pain to get the old nut of the tool, Good luck whit the Project.
I did it..... using my trusty vibrating multi saw.... cost me three blades, but it worked.
Before....
After, I cut just above the thick washer...
Great piece of kit this is...
Before....
How you going to clean that up then?
Barrels are off to the powder coaters tomorrow Mez, he can clean it up
Good result Geoff!
Well done Geoff, has the motor been apart before?
