Right, the thread has been fixed. So back on the engine, finish the assembly. All went OK, but I think there are still a couple of semi-dodgy threads (one of the oil filter bolts for example). But I thought I put the engine in, start it up and then see where it all leaks and drips... cannot imagine that the carburator won't flood or leak or some of the covers don't seep oil... then take it all out again and fix it...
So, engine completed - here it is:
In the mean time also picked up the seat from the upholsterer. Sometimes it pays to leave it to the professionals: The seat now looks absolutely fantastic! But he had to take the whole thing apart, reshape and resew it. The shape from the UK was just too far off. It however does the usual trick and stands back a bit from the tank at the tip of the seat. Not sure what can be done about it yet - the cover does not seem too tight, maybe heat is up a bit and bend it for a while? Ideas anyone?
So, engine in - here it goes! Went well until I tried to put in two bolts, one on the front frame bracket and the one on the bottom and could not get the M10 bolts in... WTF? After thinking hard I worked out that when I put the case together I put in two of those joining plugs... and some must be 8mm diameter inside and some 10mm? Or I should not have put any in at all... So, I was somewhat screwed. Last thing I want is pull it ALL apart again. Well, the drill comes in handy and I just drilled it out! Worked well on one and then the other starts spinning, the little f&*^er... after breaking two drill bits I gave up and put in an mate bolt... not perfect, but as it is the one right on the bottom of the engine I think I can get away with it - it doesn't add a lot to the solidity of the engine mounts.
So, for anyone who is about to put the cases together: Watch out for those little suckers, not sure how I mixed them up / used the wrong ones, but it happended.
The final result after much swearing and cursing:
Carburettor in, and all connected. Let's see if the start up works this weekend, despite the tank not being ready yet.
Still more filling and sanding to do... it has more dents than I first thought... not deep, but messy ones that take lots of shaping and mucking about. Sometimes wonder whether stripping it down completely was the right path to take, but too late now! Will get there, just takes time...
Really getting excited now... it is great to see the old girl come to life again. It will look fantastic when the nice bits go on (tank, covers, mask and seat).
