Eric66 34L Resto
Re: Eric66 34L Resto
Eric66 wrote:Ya can still buy OEM for $87US per wheel from boatnet!
This was on his Transalp project bike Eric, frigging steep though when you see how much Geoff paid for stainless spokes to be made up.
Post by Eric66 »
xtzrick wrote:Best way to get the piston out is to reconnect it to the master cylinder & pump it out with brake fluid. :thumb:
Would do that if I had a master cylinder and line, they are on the order list.
Eric66 wrote: Would do that if I had a master cylinder and line, they are on the order list.
Rick is right Eric, its the ONLY way of getting the piston out safely, I've tried evrything in the past.... I would wait till you've got a cylinder to pump it out with.... or use a mate's... :nod:
Post by Eric66 »
Inspired by Tenere Mikes detailed explanation for dismantling forks I decided to see what lived inside mine. As you can see the bushes have some wear but basically nothing to bad.
Checked prices through boatnets powersport section under Suzuki upper bush 51152-48B31 $9.60 each, lower 51153-48B31 $11.13, oil seal 51153-08D00 $12.08, dust seal 51173-15D00 $12.17, so for around $90 I will replace everything! :star:
Some funny wear here?
Inside lower all nice and clean.
And this looks OK too I hope.
Post by Eric66 »
Decided to pull the perfectly good cover off my seat and see how the new one looks, straight away I new there would be problems! This is the old one un-stapled sitting on the seat, a REALLY GOOD FIT.
This is the new on, looks like a potato sack!
Both covers side by side, as you can see the new one is way too wide at the front and does not follow the shape of the seat.
This picture shows the pattern line in blue of the old cover, no where near what the new one should look like! I have only seen Just Dans efforts with recovering and it looks like he has the same issue, has anyone used these covers and successfully fitted them without the loose look at the front of the seat?
Eric66 34L Resto
Well from reading a post from Mr Lambeth on the HUBB, he reckons the foam is shagged in most guys seats & was working on foam replacement.
The biggest problem is the gap by the front between the seat, especially when your sitting on it.
Dave said in his post, the foam looses its strength causing the bend & im guessing your foam has lost some of its shape Eric?
marcm
Post by marcm »
mine didnt look great when i put it on,i have resorted to spray contact adhesive before in an effort to not have wringles on top.
anyway couldnt find any when i was doing tenere seat so i just sat on it for 4000 miles and its looking ok now..if bikes not going anywhere just stick a 70 kg dummy on it for few weeks...
:scratch:
Post by Eric66 »
It's not the shape of the foam but the pattern of the red cover. If you look at an original seat the red follows the edge from horizontal to vertical along the seat. These covers come way down the sides. Look again at this.
The seam should follow the edge of the seat horizontal- vertical. As does my old cover which fits perfectly. The blue line should be the pattern of the red fabric.
So who supplied the cover Eric?
Post by Eric66 »
Some Dude called Dave Lambeth, got it of E-Bay.
