Page 3 of 3
Re: Clearcoat carbon fibre tank protector
Posted: Mon Nov 19, 2012 4:05 pm
by domtrails
Nice work that man............
Posted: Tue Feb 26, 2013 10:44 pm
by Rich
nice work, if you spray with two pack clear laquer it will bond to the resin, Acrylic laquer is a bit "soft". use hairspray to stop the carbon fraying.
Posted: Sat Mar 16, 2013 8:10 am
by Evans
Hi
I'm working on a project in Spain and on my bike here. I'm using the same technique as the tank protector to reinforce and enhance the plastics. Since there's quite a lot of clearcoat carbon on the bike I wanted to downplay it so used a matt finish. I use PPG matt as it's already pre mixed and gives me the same effect, which is difficult using flatting base added to a gloss. I use SP 115 resin to make the piece, then brush on coats of gloss PPG clear, rubbing back with 320 grit until there is a flat surface then spray a final coat of PPG matt. The side stand is from a solid bit of scrap carbon off cut.
Posted: Sun May 05, 2013 5:00 pm
by Evans
I've found silver twill ( glass cloth with an aluminium coating) available from Easy Composites ( as well as a variety of carbon twill weaves). I made a sample from the mould for my screen. Too bright for a screen in my opinion but great for a belly pan. A bit stiff to drape but keeps it's weave pattern better than carbon twill.
Posted: Sun May 05, 2013 11:18 pm
Different.
M.
