more stickers
new ignition switch with 2 keys
dash on and new led blinkers
started sanding back the plastics to remove sun damage 1 side panel done
the plastics are pretty scratched up going to have to do something here
parts arrived today not the swing arm kit yet bugger
swingarm kit finally arrived won't be long and i have a roller again
as the gaiters i got with my bike are green i decided to order some of these
starting to get a bit carried away again
sand blasted some more bits
after etch primer and undercoat gave them a hit with the wrinkle paint looks normal when its wet
while these were drying i used 600 wet sand paper and sanded then polished the levers ,assembled ready to fit
got some more parts
fitted the rear swing arm today still had a few mods to make it all fit
had to bend this bracket to get a little clearance
also had to take to the shock with the die grinder
now i have room for the shock to move through it's arc, it's a bloody close fit the stress levels raised slightly while grinding away at the shock
i was missing the little guard that sits on the left side swing arm bearing so i hunted around and found the neck of a plastic water container is a close fit
so with some grinding, hack sawing and die grinding
rolla
got it back on the wheels
so i though a mock up was in order
possible problem......it's huge....... the seat height is now 930mm i'm wondering how much the weight of the motor ect will lower it?
i've already got the shock on it's lowest spring seat position and the pre load is as low as possible.
good news shock works really good has firmed the rear up and the rebound adjustment works
had a hour spare this arvo so i made a start on the wiring harness
so its a mess has lots of soldered joins some taped some not just have to get rid of all the army mods and put it back to standard
Murray Walker
