Engine knock...
JoshZ7
What Bike or Bikes Do You Own?: Yamaha XTZ660 Tenere
Previously Owned Bikes: Suzuki DRZ400
Re: Engine knock...
Post by JoshZ7 »
Help!
I have an ‘07 Tenere with this same issue. First time I heard the knocking, I took it to the shop and they tightened the crank nut to spec (80Nm) and used loctite. Maybe 6 months to a year later, the noise came back, but I decided to do it myself, sure enough the crank nut was loose again, but the tab was still over it. How the nut could loosen I don’t understand, I’m thinking there must be something on the other end of that shaft that is loosening which takes the tension off the crank nut??
After putting that back together, tightening to 90Nm and using more loctite, 3 months later the noise is back. I’m not happy. Can anybody explain what’s going on?
Re: Engine knock...
JoshZ7 wrote: Sat Jun 05, 2021 12:56 amCan anybody explain what’s going on?
What is the condition of the key & keyway?
JoshZ7
Re: Engine knock...
Post by JoshZ7 »
That’s something I should mention yeah, the key seemed to be completely fine, I couldn’t see any wear on it besides a slight mark of where it contacted, but nothing that would significantly change its width. However, there was 2-3mm of play in it. This puzzled me for a long time, and I ended up concluding that it was just the way it was designed.
This play didn’t matter once it was tightened up since the nut pushed against the key.
Should it be a snug fit?
Some extra information:
2009 (not 2007 whoops) XT660Z, 50,000km.
JoshZ7
Re: Engine knock...
Post by JoshZ7 »
Oh, is this thread for my bike or the old Tenere?
Here’s a YouTube link to the movement in the keyway (this is how I found it, I then tightened it, but the play will be the same now that it’s loose again)
https://youtu.be/lJSQMFPSlPs
Re: Engine knock...
A key & Keyway (READ THIS) his snapped clean in half but most just wear out, the slot included.
JoshZ7
Re: Engine knock...
Post by JoshZ7 »
The link doesn’t seem to work for me, “database error”. I read elsewhere that it’s normal for this key to have a bit of play in it, not that it’s good, but it is normal. Thoughts?
Re: Engine knock...
Try the link again, Grant`s site was down temporarily.
There should be zero play in the keyway as it will only get worse (wear more) needs to be a tight fit.
You can search this site (top right) using the word "counterbalace" but i also post on Grants site (The HUBB) when i find something of use for the XT guys over there.
Rattle, tap or knock? check your nuts
JoshZ7
Re: Engine knock...
Post by JoshZ7 »
Thanks!
I think I’ll pull it apart and get someone to machine a key that fits more snugly, and I think I’ll tighten it up to 100-120Nm this time (80Nm is spec)
Re: Engine knock...
JoshZ7 wrote: Sun Jun 06, 2021 9:05 am Thanks!
Good man, if they Key is worn then the keyway will also be worn (wider) so a custom fit key is the way to go & like you say a bit more torque.
Re: Engine knock...
Not sure you should tighten it so much to be honest
