Danjets Honda Transalp
- Dirtybrit
- What Bike or Bikes Do You Own?: 1982 XT 550, 1981 YZ250, 2010 Triumph Tiger 1050, 1981 XR 200
- Previously Owned Bikes: Honda SS50, Yamaha RD2501973, Honda XL125, Yamaha DT175, Kawasaki KE175, Yamaha YZ250D, CT90, Suzuki RM400, Yamaha YZ250H, 1981 Yamaha RD250,1982 XT 550, 1979 XS 750, 1979 YZ 400 F.
Re: Danjets Honda Transalp
Looking good Dan, Getting there!
Danjet600
- What Bike or Bikes Do You Own?: xt600e 1991 ex australian army
yeh got a bit to go yet, those new carbs running sweet, is good for motivationDirtybrit wrote:Looking good Dan, Getting there!
Murray Walker
Murray Walker
Danjet600
bought a stainless steel 90deg 50mm mandrel bend, so i decided to have a go at the exhaust this arvo,
first made a little bracket
cut the pipe and made a bracket to mount the can
after some trial fittings i cut the bend off the can
after cutting a piece of the very expensive stainless bend $40
TOO SHORT
i had many little trail and error fittings to get it right the second time
now i'll just tack weld it together and then get someone to tig weld it
Murray Walker
Murray Walker
Danjet600
so i tacked the pipes together and then joined the tacks
and ended up welding it together with my mig using gasless wire
anyone know if welding stainless with gasless wire will cause any problems?
oh and i gave it a bit of a polish
Murray Walker
Murray Walker
Well you will soon see when your can comes flying off on a bit of corrugated road.Danjet600 wrote:anyone know if welding stainless with gasless wire will cause any problems?:
- Dirtybrit
[/quote]
I don't think you will have a problem Dan, the worst that can happen is it may crack or maybe a spot of rust, but I think you will be O.K.
Downside, No more Roasted nuts!
Danjet600
got the wheels off today
removed the old tires and inspected the rims
the usual rot around the valve stem but otherwise in fair condition
Murray Walker
Murray Walker
Danjet600
how to bodge up your bike jack bogan style
the hydraulic jack that came with my bike jack/lifter crapped itself and i managed to misplace the receipt
so i had to get the jack sorted
so get your hands on a mechanical jack from a 1965 datsun 1200 1 tonne ute, get the welder out have a few rums and start welding
welded a nut on the end so i can use the impact/rattle gun to raise and lower
go's like a beauty now
Murray Walker
Murray Walker
Lets see a movie with the rattle gun in action then mate.
philb
- What Bike or Bikes Do You Own?: Yamaha XT600E, Honda CBR900RRT, Kawasaki KH400, H1E 500, RD350LC, VF750F, Triumph T140E Bonneville & XT1200z Super Tenere.
- Previously Owned Bikes: Suzuki AP50, GSX750EFE. Honda XL100, CG125, CB400/4, CBX550, CB900. Kawasaki KH250,KH400, H1E 500, GPz750Turbo, ZXR750H2, Z1000ST, Z1R. Yamaha RD250LC, RD350LC, RD400, XT600E, XJ650 & FJ1200.
