222 loctite is the weakest of the thread lockers and perfect for the XT/XTZ, it is a liquid that hardens when in contact with a metal or when oxygen is no longer present. When you use it don't touch the tip against an metal, i just drop a small amount on the thread and screw it in.peman wrote:Zonda wrote:Put some 222 loctite on the adaptors, as they tend to come loose. I also filed two flats on the alloy "adaptor" so i could tighten them up with a spanner.
Thanks for the reply, Is the 222 the soft loctite? hard to remember which one to use, how did you put flats on your mirrors? would like to be able to remove the ball in case
i break a lever housing.
I filed two flats on the adaptor to suit a 12mm spanner..
