Cylinder and cylinder head allen bolts schematic/diagram needed
Re: Cylinder and cylinder head allen bolts schematic/diagram needed
There are exceptions to every rule :rofl:
That's a special bolt.
Feel free to check any normal bolt if it ends in 06035 it'll be an M6 35mm.
Where bolts are shown with an odd length, it will be because they have a washer, for instance 90119-06063 will be an M6 with integrated washer 60mm.
Scumfrog
59x
43F
Post by Scumfrog »
You can use stainless bolts if you use a ceramic anti seize grease. Just sayin.
Post by charliext1vj »
Interesting....but how do you then torque the bolts?
Scumfrog
59x
43F
Post by Scumfrog »
25% less they say.
Hopefully Cadno will be along shortly to clarify the pros and cons. The con being bolts could loosen.
