Sandraiders Morocco 2023
JamesinEdinburgh
What Bike or Bikes Do You Own?: 3AJ, T7 & ST
Previously Owned Bikes: 1VJ, 3AJ, PE400, PE250, PE175, DT400, DT250, SP370, Z1B, XS1100
Re: Sandraiders 2023
Post by JamesinEdinburgh »
After researching available batteries, I decided to buy two new Yuasa YB12AL-A2's for about £100. One for now and the other for the Sandraiders Rally.
I really like the Arrow silencer which cost £224 but some of the screws were lose, so I applied Loctite to prevent them from falling out.
JamesinEdinburgh
Re: Sandraiders Morocco 2023
Hopefully the stainless steel exhaust studs will make future removal of the exhaust easier.
JamesinEdinburgh
Need to get an exhaust guard.
Suggestions anyone?
JamesinEdinburgh
Trying to set the sag was a saga.
Despite telling Wilburs the weight I wanted my new shock absorber set to, I needed to remove the battery holder to be able to turn the adjuster wheel nearly 30 times!
Dave Lambeth reccomended I tell Wilburs the setting in Newton Meters but the website no option :-(
The new shock absorber cost €480 with over £100 import tax.
JamesinEdinburgh
Also fitted bark busters. The yellow is not quite matching
JamesinEdinburgh
Next job is to refit the battery holder and make sure the electrical components around that area still work OK.
Jenik
What Bike or Bikes Do You Own?: XT600Z
Post by Jenik »
JamesinEdinburgh wrote: Wed Dec 28, 2022 9:13 pm Who do you hire the Honda's from please, Jenik?
always with the same guy http://www.atlantic-moto.net/index.php?page=moto
There are not so much options where to rent such bikes. KTM are too expensive. My recommendation is to pay deposit in cash, then you to avoid additional charges in case of motorbike damage (as per experiences). If youre interesting I can share direct contact including recommendations.
http://www.supertenere.cz
currently 3DS (3AJ), previously XTZ900 (95,25 Nm by 5484 rpm/min, 85,64 PS by 7271 rpm/min)
Sulev
What Bike or Bikes Do You Own?: 1989 XT600Z, 2023 Tenere World Raid
Previously Owned Bikes: TT600R
Post by Sulev »
Hi James, i am new here but it was interesting to see that the same Harry's video inspired me also to do exactly the same project like you will do. My plan is to go 2024. This summer i bought the bike (3AJ). Plan is to restore it from inside out (like Harry does with its cars and bikes). Then summer 2023 to do some test events and 2024 spring there will be Sandriders.
j0epere
What Bike or Bikes Do You Own?: Yamaha XT600Z 1VJ
Suzuki XF650 Freewind
Post by j0epere »
Sulev wrote: Fri Dec 30, 2022 1:46 pm Hi James, i am new here but it was interesting to see that the same Harry's video inspired me also to do exactly the same project like you will do. My plan is to go 2024. This summer i bought the bike (3AJ). Plan is to restore it from inside out (like Harry does with its cars and bikes). Then summer 2023 to do some test events and 2024 spring there will be Sandriders.
Hi Sulev,
Your name hints that you might be an Estonian, is that correct?
JamesinEdinburgh
Jenik wrote: Thu Dec 29, 2022 11:11 am
Thanks for the recommendation Jenik
Looks like the Honda 250 has 15L tank, so might get good range. I'll check them out next time :-)
One of the guys on our tour with Chris Scott dropped his BMW310 on a sandy corner, broke a few plastics and had a €200 bill :-(
