SOLVED -2008 Tenere Wont start - CEL Flashing - Wont crank
Re: SOLVED -2008 Tenere Wont start - CEL Flashing - Wont crank
Their switched on the negative aren't they? constant feed, short........ well done for sorting anyways :congrats:
I am with jibber on that one. One of the horn wires is coming straight from the ignition switch. If it is not connected to the horn it might have touched the frame or another cable housing (earth) causing a voltage drop.
