Got my 1Vj but it's a 1Vk
Joly
What Bike or Bikes Do You Own?: Xt600z ivk
Previously Owned Bikes: Xrv750
R1200GS
XJ900
850 LEMON
A65
T140
C15/B40
Re: Got my 1Vj but it's a 1Vk
Post by Joly »
Hi
I've got a 1vk here in The Philippines. Sub 200 serial number.
Was this bike restricted in power for the Swiss Market and if so how would I de-restrict it?
Regards,
Jolyon Image
Yes. Mainly jet sizes. They had 130s instead of 140/145/150 that the other uk/ European ones had. Middle settings would be 46 pilot, 145 main, 125 secondary carb. Needles clipped in middle ring. It might have a restriction in the inlet boots but I doubt it. Airbox may be restricted, so just open it up at the back.
Joly
R1200GS
XJ900
850 LEMON
A65
T140
C15/B40
Post by Joly »
Thank you.
Do the bikes use Mikunis and do you know if the jets are available anywhere?
Jolyon
Hi there,
as far as I know no power restriction but a leaner carb setting and higher gearing (for less noise, targeting the noise measurement setup of that time).
There is a spare parts list which has the parts labelled 1VK in it.
So there is a different needle set in the primary carb, and the return spring for the membrane in the secondary carb has a VK number as well (so may open later). Carbs are Teikei brand.
Air filter intake is from under the seat like in 3AJ model, muffler has a different end pipe.
Rear sprocket is 39 instead of standard 40
Both fenders have extensions (are longer)
Seat has no helmet lock
Side stand switch
I will PN you the list for reference.
Joly wrote: Fri May 06, 2022 6:12 pm Thank you.
Jolyon
If you have a dealer, or supply chain, the jets and most other (not all) carb parts are available genuine. Check on fowlers parts for part numbers and sizes, or download the parts list ( and print it off on someone else’s printer😁). Some part numbers have changed but using the old one at the dealer will bring up the new one on their computer. You can sometimes get carb kits for drilling jets out and needle changes etc, but I’d go for the genuine option first. The parts list has the Swiss option separate so you can compare differences.
Good looking bike.
I have this file but couldn’t upload it. So with jibbers permission, this is a link to a download on another site. It’s not theirs either, it’s been around for years on the net. If you search it, their should be several places to download it from.
https://xt-tenere.com/wp-content/upload ... -Fiche.pdf
Joly
R1200GS
XJ900
850 LEMON
A65
T140
C15/B40
Post by Joly »
Excellent.
Thank you.
I'll have a look.
Are 3TB carbs the same as 1vj?
Jolyon
Looks a different part number but same basic carb. A few differences in choke, and probably jet size. It would fit and work.
Joly
R1200GS
XJ900
850 LEMON
A65
T140
C15/B40
Post by Joly »
Thank you. I understand the 1vk Swiss bikes run lean to meet emission regs. I don't want a lean running bike in The Philippines' heat.
Some spares have surfaced 69 miles away, including 3tb carbs, hence the question.
Regards
Jolyon
BMurr
What Bike or Bikes Do You Own?: James autocycle
BMW R100GS
1VK
Previously Owned Bikes: MTX126, Xt600 43F, Kawa GT550,750,GTR1000, BMW R100GS (x2)
Post by BMurr »
Joly wrote: Sat May 07, 2022 2:23 am Thank you. I understand the 1vk Swiss bikes run lean to meet emission regs. I don't want a lean running bike in The Philippines' heat.
Regards
Jolyon
What was your airbox like, did previous owner block off the forward intakes that took hot air in from above engine? Did you check if jets previously changed? Does it have a helmet lock, mine has locking seat and I'm guessing that the locking side doubles as a helmet lock.
