ABOUT TO BUY?
Re: ABOUT TO BUY?
With a quick bit of research, the 4PT tank should fit the 3TB BUT you will have to change the seat, sidepanels and tail unit for a good fit, just found a thread bt DL over on hu
http://www.horizonsunlimited.com/hubb/y ... ther-49168
bowen93
What Bike or Bikes Do You Own?: i just bought a 1996 yamaha xt 600e as a local run around and have owned a yamaha fzs1000 fazer for the last 13 years also
Previously Owned Bikes: xlr125,cg125, suzuki bandit 600, 3x suzuki bandit 1200, honda vfr 800, kawasaki zzr600,1100,1200, zx14.
Re: Another Question XT600E
Post by bowen93 »
ZINTXO wrote: Tue Nov 27, 2018 8:48 pm XT600 E 3TB 1996.
Thinking of fitting an Acerbis tank as the original side panels are not good and have been repaired a few times by the look of them when I got them off. I am unsure if the side panels will fit with the Acerbis tank as there does not appear to be anyway on the tank to put the front rubber retaining thingy's in. I can buy from Fowlers of Bristol the necessary rubber inserts and bolts to mount the panels which will be an improvement on the self tapping screws that were fitted by previous owner!
Question if tank is replaced with the Acerbis type do I have to change the side panels or is something available from a different model or how do I get around the (as I see it) problem?
Also the header pipes are not great so was looking at Stainless replacement from these guys....
https://www.ebay.co.uk/itm/Headers-Head ... 1102205109. A German company. Has anyone had any dealings with them or can you recommend some other company?
Sorry for being a bit thick but just finding my way around the bike but do honestly appreciate the help which is available from this forum.
Regards Reg.
sorry to bother you it sounds like i may have just bought your xt600e if you sold it. P997 RMR ? if it is the bike could you tell me a little about the history of it please that you know ?
thank you
