34L Carb
Benjii
What Bike or Bikes Do You Own?: 2009 Honda CBF 1000
1997 Suzuki GSF 600
1997 Kawasaki KDX 220
1983 Yamaha XT 600 (34L)
Re: 34L Carb
Post by Benjii »
OK, got all the replacement bits for the carbs.
I've split the bodied, cleaned them up & replaced everything but am stuck on the Air Cut Off Valve.
I got the cover off, removed large spring, diaphragm & removed screw.... how do you get the seating ring & pin out???
Do you just pull it out or is there something else holding it in??
BEN
Benjii
1997 Suzuki GSF 600
Re: 34L Carb
Post by Benjii »
THANK YOU Mezo
The guide you sent me was very useful. Seeing the pics gave me the confidence to go ahead and use my vice grips to pull the Air Cut Off Valve straight out of its seat. I was in there good and tight.
It was the same with the Float Valve seat but all good now.
Strangely,, there is no large diaphragm on my slide valve,,,where it should be is a sealed unit that can't be opened!! Was there different set ups on different models??
BEN
Re: 34L Carb
Post by xtrider »
The older secondary carbs had just a piston that's a close fit to the bore instead of the rubber diaphragm , they need to be real smooth and no corrosion for that slide to move freely. Not a great setup , slow to respond compared to the rubber boot version.
