tt600 36a/59x rebuild
Re: tt600 36a/59x rebuild
Does it have MAGNESIUM stamped on the casing? if so dont alloy weld it.
- peman
- What Bike or Bikes Do You Own?: tt600 36a
tt600 59x
pe175 t - Previously Owned Bikes: nothing worth mentioning. unfortunately
hey mezo! i remember you from adv, nice demise that was!
yes it has magnesium on it, i thought the xt600 had alloy side covers?
(xt engine this is) all the one's i got have magnesium on them.
can i use liquid steel or something?
Yes ADV, thats why were all here.
If you Google "welding magnesium" you will see its an art, if you give it to a mate of a mate that knows a bloke who can "weld alloy" you will end up with a fucked side cover.
JB Weld or something similar will surfice.
- peman
tt600 59x
That's the stuff i was thinking off, couldn't remember the name, excellent that will work, thank's
aaand a teaser pic!
Got the shock back from rad shocky at moorooka mile it has a ktm spring apparently
thicker spring witch is good for my 120kg butt, got it powder coated and new bush fitted.
aaand a teaser pic!
Nice hammer!aaand a teaser pic
- peman
tt600 59x
hey! you know the old saying if you can't tape it on hammer it off,ActionManMelb wrote:Nice hammer!aaand a teaser pic![]()
and if you can't hammer it off tape it up!
oh you just missed out on the conrod kit i had on ebay a couple weeks ago
- peman
tt600 59x
OK was playing with engine bits this week and organised the engine cases to be bead blasted and 2
threads helli coiled the bottom oil filter bolt as usual, well i was surprised when they came back!
dumb bastard!
he helli coiled the front of the hole mate!! so now i have to plug the back of the rooted thread so to not loose oil pressure,
and drill out the oil cover hole.
AND THEY LET THE NEWLY BORED CYLINDER GET RUSTY!
I have learnt one thing this week, do as much as you can yourself and learn as much as you can
to do the things you can't.
otherwise the cases look great, except for the crack which I'll fix myself.
[imghttp://imageshack.us/a/img46/8867/o20p.jpg][/img]
this is oll smokey! motor got dusted i think huge clearance
and damage also high comp piston. junk now.
and look at the old oil pump! must have had low oil pressure
and the pick up was full of sealant strands, black bits blue bits clear bits
found a good one will use that, pulled it apart and cleaned it out and put
back together.
dumb bastard!
back together.
- What Bike or Bikes Do You Own?: Yamaha TT 600 1984
- Previously Owned Bikes: Vespa Rally 200, Vespa SS 50 and alot more old (real) Vespas!!!
and.....? - Location: Hamburg , Germany
"I have learnt one thing this week, do as much as you can yourself and learn as much as you can
to do the things you can't."
So true!
When I bring something to a shop and they say "no problem" I´m in high allert.
One should make a video from contact with the lad behind the desk.
Then, when they fucked it up, show it to them...
cheers Olli
PS: nice shock! ;-)
So true!
cheers Olli
PS: nice shock! ;-)
55W1985
What happend this week Oli?.....
There are two things i didn´t do on bike mech myself.
1) shock rebuild
2)Honing the cilinder
The rest I was the guy behind the bench.......
After the rebuild was done the pick up coil started to fuck up.....so a specialist was needed.....and trust me I was as you say! Preying......
they wouldnt fucked up completely.
As Oli said orgasmic shock!!!!!
1) shock rebuild
XR650L(1994) 55W (1985)
- peman
tt600 59x
Thanks for the replies guys, it's a bit gut wrenching the money you put in and
for someone to half ass it like this, lately it's been worse even at work.
now for up date,
crack be gone.
gash be gone.
gash be gone too.
and the boats order turned up! shit getting done now!
got the crank been done at serco as we speak. 32 items in total
cable guides, chain rollers, rubbers, gaskets, etc.
and the new piston, 10.5:1 should wake it up a little.
now for up date,
crack be gone.
gash be gone.
gash be gone too.
