Danjets Honda Transalp
Danjet600
Re: Danjets Honda Transalp
Post by Danjet600 »
finally after waiting since 10/08/11 my xl600v 1996 model carbs turned up :funkynanna:
69euro :thanks: it's super clean
there's a few differences
had to remove the TPS sensor and a little bracket then it fits straight in, the only problem is i don't know what go's in
this little hole
if i block it up it floods, but it's sucking unfiltered air into the carbs somewhere :scratch:
anyway it starts and runs much better now :nod:
it was a great cure for a bad case of mondayitis :biggrin:
and here's some more pics just for the hell of it
looks kinda mean like this slywink:
Murray Walker
Is that port actively "sucking"? :sherlock:
It may just be the atmosphere balance port for the constant velocity diaphagm.
It may be just supposed to have a tube going to the aircleaner, like the Tenere's have.
Danjet600
Post by Danjet600 »
ActionManMelb wrote:Is that port actively "sucking"? :sherlock:
yep actively sucking :nod:
Murray Walker
OK, we need the manual now, with a schematic of the carbs and vacuum pipes.
But I will take another guess and say that it may connect to the other carb in a balancing function.
King of Posting
King of Posting
Post by xtzrick »
I'd go with this guess Actionman.
The port at the top of the inlet is missing on the new carbs (Danjet, it stops a vacuum forming under the diaphram, allowing the diaphram & slider to rise).
If it were mine I'd attack the area I marked in blue with a bastard file & smooth out the air intake, once I knew it ran ok first of coarse :innocent:
Dirtybrit
Post by Dirtybrit »
Looks like that will add a little more eat to your nut roaster Dan! :lol:
Danjet600
Post by Danjet600 »
Rick[/quote]
it runs really nice i don't want to butcher these carbs :nono:
i'm waiting for some pics of the vacuum pipes, they apparently go to a seperate little air filter :scratch:
Murray Walker
King of Posting
King of Posting
Post by xtzrick »
Danjet600 wrote:The port at the top of the inlet is missing on the new carbs (Danjet, it stops a vacuum forming under the diaphram, allowing the diaphram & slider to rise).
i'm waiting for some pics of the vacuum pipes, they apparently go to a seperate little air filter :scratch:[/quote]
Can't blame you for not touching your carbs, I can't help tinkering & bringing more misery on myself, that's just me smile:
If you want to see what a seperate filter looks like, your 600E might have one on it (later models have it, not sure about yours) it's a rubber tube joined to a metal elbow coming out the carb from the diaphram area with a plastic cylinder near the end of it, probably under the seat.
Cant see from the fiche either Danny :scratch:
I reckon that sounds right, black pipe with 90° angle up to one of them small filters.
Danjet600
Post by Danjet600 »
MEZO wrote:Cant see from the fiche either Danny :scratch:
it's from a 1996 model, i can't find a parts fiche for this model :dunno:
well next is to order is some tires and i've got a lead on the little plastic 90 deg fittings for the carby to fit the extra air filter thingo
what else, sticker kit, front caliper rebuild, new front brake pads, machined front disk, new/2nd hand clutch cable, and i need a 90deg 50mm stainless steel bend so i can mod the exhaust, get the seat recovered i'm thinking blue suede leather (mez's fault again :stir: ) mmmmmm what else? got to start the body work :huh: not my favorite task
Murray Walker
