Hi Geoff, its after midnight here, so i will do a more detailed post tomorrow.
Do not pull the engine yet. I would be repairing this with an epoxy/metal patch material.
I have been fixing alloy casting on auto transmissions with this stuff for longer than I care to remember.
More tomorrow.
- Founding Member
- Founding Member
- What Bike or Bikes Do You Own?: 7 x 3AJ Teneres
Honda Dax - Previously Owned Bikes: Triumph Tiger Cub, Garelli Tiger Cross, Triumph Trophy 650, Honda CB250 G5, Honda CB750 K7, Yamaha DT175MX, Honda CB250 Super Dream, Yamaha RD350LC YPVS, Honda XR250, Yamaha XT600, Suzuki PE175, Yamaha YZ125, Yamaha RD500 V4, Yamaha XT600 Tenere (3AJ), Kawasaki ZX10, BMW R100GS PD, Honda XR600, Honda Varadero, Honda Africa Twin, Honda Transalp, Triumph Thunderbird, Ducati 900 Superlight FE, Ducati 750 SS, Honda Fireblade, Kawasaki Versys 650, Suzuki GT750 Kettle, Super Tenere
Hi Dave, I'm not rushing into pulling the engine out just yet.... I bought some of that plastic padding super steel epoxy stuff last night, I got the one thats specifically designed for repairs to alloy castings....
I drained the oil on the bike this morning, thoroughly cleaned the area of the oil leak with some electrical contact cleaner, roughed it up with a hacksaw blade & smeared the area with the epoxy stuff, making sure I firmly pressed the stuff into where the oil was leaking from.
I will leave it now till Thursday (when I get my mid pipe back) & give it another try...
Fingers crossed.......
- Founding Member
I have used this product for years. It is a two part epoxy with metal powder filler.
Probably very similar to JB Weld.
When mixed, it has the consistency of honey, so it flows into corners well and air bubbles will float out.
The downside is that it flows too well and you sometimes have to construct dams and restrictions from modeling clay (plasticine?).
It sets in 10 mins, and can be sanded in an hour. As I said earlier, I have repaired many castings on bikes,transmissions and gearboxes and never had a comeback for a leak.
If you want some i can post some over.
They do one for alloy casing called QuikSteel Aluminum Reinforced Epoxy Putty
Interesting a guy had used it on his bike on a cracked head & worked (according to BlueMagic)
Danjet600
- Founding Member
- What Bike or Bikes Do You Own?: xt600e 1991 ex australian army
i was hunting around on the net and found this stuff
might be just what the doctor ordered
[youtube]SwyglwkZcCU[/youtube]
Murray Walker
Murray Walker
- Founding Member
That looks like good stuff Danny...Danjet600 wrote:i was hunting around on the net and found this stuff![]()
anyway I got some plastic padding super steel epoxy stuff, which I guess is very similar to the stuff Dave was talking about (thanks for the offer of sending some over Dave, I might take you up on that)... anyway I smeared the area with it & left it for a couple of days... got my mid pipe back last night so I re-assembled that this morning... I then decided that I would pull the left hand side cover off the engine & replace the starter one way bearing 'cos mine was a bit intermittent & I wasn't very happy with it... I'd managed to pull off the flywheel from the crankcase half I was given the other week & the bearing on that one was good, which saved me 200 quid...
So I stripped the flywheel, pulled out the bearing & dropped the fucking thing & it broke into 26 fucking pieces on the floor....
Soooooo once I'd found all the bits.....
Got it all back together, the starter sounds much better & the bike sounds bloody great... but... still leaking oil, I missed a bit of his weld with the epoxy stuff & there seems to be a pin hole where the oil is seeping from..... bastard....
So tonight I've drained the oil AGAIN, cleaned it up again & smeared a bit more epoxy stuff on it... I'll try it agin in the morning.....
- Founding Member
So her indoors made me a HUGE plate of chicken nacho's (one of my favourite's) to make me feel better .... & after 4 bottles of San Miguel... I do feel a bit better
What a pain in the arse Geoff
Oh well the tucker looked nice, and i miss the old San Miguel (reminds me of Spain)
M.
M.
That shit works. Worked to patch my case in the desert of Texas after a drop on the rocks. Set in about 30 minutes in the Texas sun and I rode out. Bugger held to the day I took it to the aluminum welder to have it sealed up properly.MEZO wrote:They do one for alloy casing called QuikSteel Aluminum Reinforced Epoxy Putty
- Founding Member
I'll find out this morning if its worked.....
Oh well its not all bad, I won this last night.... £20 ... bloody bargain
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 522wt_1139
