https://www.ebay.co.uk/itm/223102658493
This supplier can sell different size oil drain plugs if you wanted to measure temp from that location.
Oiltemp. sensor on 1VJ
Re: Oiltemp. sensor on 1VJ
That`s good value, well spotted.
Sainty
- What Bike or Bikes Do You Own?: 1984 XT600Z Tenere 34L, 2007 GSF1250 Bandit, 1977 Suzuki GT550, 1954 AJS 350 and 1981 CX500C (custom maggot)
- Previously Owned Bikes: XT550, XT500, XL125, GT550, TS100, XS750 amongst others
I got one of these on a whim during the first UK lockdown last year and replaced the engine oil drain plug on my 34L with the supplied sensor. On a warm day (30c) the temp displays 80 to 90C when stationary. On a 20c day it's generally around 70 to 80c stationary. It drops 5 to 10c when cruising. I've since removed the PCB from the flimsy case and mounted it in an empty xt Speedo case I had lying around.
The voltmeter works great too.
https://www.ebay.co.uk/itm/143569639976
dzl
- What Bike or Bikes Do You Own?: 2001 TT600R, ex army XT600, 34L Tenere, 2001 FZ1, FJR1300
Something like this would be better in between oil pipe and oil cooler. DR650 oil pipe flange bolts are 30mm apart. May work in this application. I would always recommend to have a quality magnetic sump plug in these bikes so wouldnt lose that for an oil temp guage..
https://adventurebikeaustralia.com.au/p ... mp-sensor/
and use one of these with it
https://www.mxstore.com.au/p/Trail-Tech ... FkEALw_wcB
