3AJ choke push/pull (no cable)
Airbox, Fuelpump, Carburettor
jim
What Bike or Bikes Do You Own?: XT600Z 3AJ, Yamaha Tracer 900 GT
Previously Owned Bikes: Honda CBX550, Norton Commando 850, Yamaha FJ1200
Post by jim »
Hi All,
Does anyone know a supplier/part number for a 3AJ choke push/pull (no cable).
I want to get rid of the choke cable, and just have the choke mounted at the carb.
Thanks, Jim
Bowler
What Bike or Bikes Do You Own?: -Yamaha XT600Z Ténéré '90
-Yamaha MT-09 Tracer '15
Previously Owned Bikes: -Honda XL500S
-Suzuki GSX1100E(T)
Re: 3AJ choke push/pull (no cable)
Post by Bowler »
There's a post on this forum about that:
viewtopic.php?t=1139
And member motorang also has a few tips about it:
https://motorang.com/motorrad/tenere_tips.htm#5
jim wrote: Mon Sep 14, 2020 9:47 am Hi All,
Thanks, Jim
Use the search Jim (top right) "CHOKE PLUNGER" :rtfi:
jim
Post by jim »
Thanks Bowler and Mezo.
From these links, looks like the OEM part is 2KF143710100.
On MSP website this sells for £96,!!!and says it is suitable for 1987 XT600 (no mention of 3AJ). Probably still work???
At that cost, think I'll stick with cable until I strip bike over the Winter, then see if Mikuni alternative mentioned in the posts might be the way to go.
I just used a 3TB one off an old carb I had lying around.... trouble is with the 3AJ, you can't pull away with choke on and turn it off on the move... cable one is better.
