If I'd known I'd have clagged a Tenere sticker on yer bike.....xtzrick wrote:
Yes, that was my 4MY, it was a last minute decision to go.
- Founding Member
- What Bike or Bikes Do You Own?: 7 x 3AJ Teneres
Honda Dax - Previously Owned Bikes: Triumph Tiger Cub, Garelli Tiger Cross, Triumph Trophy 650, Honda CB250 G5, Honda CB750 K7, Yamaha DT175MX, Honda CB250 Super Dream, Yamaha RD350LC YPVS, Honda XR250, Yamaha XT600, Suzuki PE175, Yamaha YZ125, Yamaha RD500 V4, Yamaha XT600 Tenere (3AJ), Kawasaki ZX10, BMW R100GS PD, Honda XR600, Honda Varadero, Honda Africa Twin, Honda Transalp, Triumph Thunderbird, Ducati 900 Superlight FE, Ducati 750 SS, Honda Fireblade, Kawasaki Versys 650, Suzuki GT750 Kettle, Super Tenere
- Founding Member
Started wiring up Tenere 2 this afternoon....
Got a slightly modified 3TB loom, Super Tenere handlebar switches, 3AJ lights.... hmmmm
What I need is a colour wiring diagram for an XT600E, anyone got a link?
Took Snow White out for a run tonight to see if I'd cured the leak on my oil tank...... got caught in the biggest fucking downpour I've seen for years..... and the tank is still leaking, but, I think its the copper washer on the drain plug...NOT the o rings....
Now the bike needs some serious cleaning....
- Dusty John
- What Bike or Bikes Do You Own?: 1990 XT600E, CRF80
I can help with the wiring Diagram Geoff but I cant work out how to attach a file??? Any suggestions.GeoffD wrote:Started wiring up Tenere 2 this afternoon.......
What I need is a colour wiring diagram for an XT600E, anyone got a link?![]()
John
Is it a colour one? i could only find black & whites with a quick Google image search, just email it to me & i will host it, if its colour.Dusty John wrote:I can help with the wiring Diagram Geoff but I cant work out how to attach a file??? Any suggestions.GeoffD wrote:Started wiring up Tenere 2 this afternoon.......
John
- Founding Member
Hi Geoff,
This is rough, just a photo of the book on the floor, but it should be of some help. It is for a 1988 3AJ.
You may get better res and magnification if you go directly to photobucket to look at it.
In fact if you down load it and put into Photoshop or similar you can mag up to a useful size.
Dave.
Dave.
There`s a PDF of that drawing in the hot links section here, not sure if it works with the XT600E though
- Founding Member
I've got that one Dave, but thanks anyway mate... it was pretty clear too.
There seems to be a few differences between the 3AJ and the 3TB wiring, I'll get as far as I can then I'll ask more questions....
I'm wondering about the ign coil too, as I'm now using TCI ign instead of CDI The coil will be different, anyone got a pic of a TCI coil?
- Founding Member
If you can email it to Mezo, he'll be able to sort it.... cheers JohnDusty John wrote:
John
- Founding Member
Mezo where will I find the index for that black & white diagram?....
Just found it on my hard drive Geoff, this should be it.
The whole manual is on on the HUBB index page at the top, that where i got this originally.
