my 3AJ has been leaking sporadically for the last 2 weeks.
The oil droplets are coming from the bottom of the frame. See pic. It's marked in red.
I thought that the tube above the red square was coming form the engine breather but it's actually from the carburettor and absolutely dry so it's not the perputrator.
A friend said it's probably related to that oil sludge build up on the left. But I cleaned it off a few days ago and it's still leaking occasionally.
The leaking oil is fresh (I changed it a few weeks ago) and not black and sludgy.
I touched the entire area around it, frame and the suspension linkages. Apart from some grease those were clean.
The skid plate is clean too so it's not coming from the engine.
I checked the oil tank but apart from grease it's relatively clean. I'm absolutely out of ideas.
Last week I also dropped the bike and the leaking gas also had some oil in it as the resulting stain didn't dry off.
I don't think that's related to the leak though
