Yami´s engine thread
Yami
What Bike or Bikes Do You Own?: Many
Previously Owned Bikes: To many
Post by Yami »
I will take some engines apart and not doing this before I know I will be asking
a lot of questions. Better have it all in one thread then start a lot of new threads every time.
Hope you guys read the thread and help me out.
First, what special tools do I need?
I know I might have to purchase a flywheel puller and a tool for dismantling the valves.
Where can I get those to a reasonable price?
Second, I will start dismantling and fix the parts below on the picture.
Is it ok to sandblast all surfaces on these parts (rocket cover, valve head and cylinder head)
or should I avoid doing it somewhere?
I will of course dismantle all internal parts before sandblasting. Better to ask then doing anything wrong.
xtrider
Re: Yami´s engine thread
Post by xtrider »
I sandblast everything, well on aluminum I use glassbeads but a fine sand works. I don't blast the inside area much but it won't do any harm, but definitely stay away from the cam journals, put a good tape on them to make sure you don't hit them. I take a light face cut on mating surfaces anyways(not the top of head and valve cover).
For valve removal the special tools works best but I've used a tall "C" clamp that I welded some standoffs on opposite side so the keepers can come out and put back in. If the valves are in good shape I have lapping compound to reseat , but it is limited. Get a set of tips for an air blaster that are long tubes so they can be shoved down in the holes to blow all sand/gunk out.
Good quality torque wrench is a must
I use 1/4" and 3/8" drive allen head sockets so I can use a rachet on allenhead bolts rather than just the standard allen wrenches and "T"'s.
good set of 6 point socket and wrenches to not round boltheads.
27mm and 30 or 32mm impact sockets = crank nut and balancer nut ,clutch nut is one of those also.
@ XTRIDER, have you found anything for removing the clutch arm bearings?
Yami
Post by Yami »
Noobs as I am, is there some tools for removing bearings in Engines?
Normally in Swingarm and so on I just knock em out.
@xtrider, that was good info, thanks
Seemes to be a lot of different flywheelspullers and valve tools out there.
Can you please point out what kind I need to purchase for managing TT and XT´s?
Some Ebay link for example.
Not really sure what you mean with "light face cut" but I can guess. Think I know what can be sandblasted now
and what isn´t good doing.
marcm
What Bike or Bikes Do You Own?: 34l tenere,it 175,rd 350lc,yz 465,250lc,yz 125 g 2 off,
Previously Owned Bikes: a few...
Post by marcm »
Blind hole puller is the device either with slide hammer or one with legs,you maybe able to improvise using a rawl bolt with a pair of vise grips and a hammer if you warm the case up carefully with a heat gun a bit...
Be careful not to destroy bearing too much if possible as they get harder to extract when there's fuck all left to try and get a purchase on..
Yami
Post by Yami »
marcm wrote:Blind hole puller is the device either with slide hammer or one with legs,you maybe able to improvise using a rawl bolt with a pair of vise grips and a hammer if you warm the case up carefully with a heat gun a bit...
Thanks for info, appreciate all help I can get. smile:
Todays work.
Just made sure the threads was ok. On my last XT I had to helicoil some of them.
But these are fine.
Found a tool to pull of the valve springs with.
Tried to mark them with the dremel. Very hard material in those valves.
After 1 and 2 the marker was shot. Have to bag them instead to keep track of them.
First valve is out, but I wonder if there is some more to take away before sandblasting?
That in second picture wont come of but maybe it shouldn´t.
This is the reason i say "refer to Clymer manual, OEM service info & the OEM part fiche" in combination. :rtfi:
The OEM part fiche will give you more detail in how the bike is put together. :thumb:
I think you are refering to number 5 in Mezo's diagram. Use a magnet to help lift it out.
Yami
Post by Yami »
Mezo wrote:This is the reason i say "refer to Clymer manual, OEM service info & the OEM part fiche" in combination. :rtfi:
I saw that answer coming Mezo. smile:
I am a bit unsure of things when it´s unknown territory the whole way.
Warned you about many dumb questions in this thread. :rtfi:
But it might help someone else too.
How do you get that last thingy (number 5) out without damage anything?
ActionManMelb wrote:Use a magnet to help lift it out.
Yami wrote:How do you get that last thingy (number 5) out without damage anything?
:popcorn:
Over to you Dave. :thumb:
