Cause of a weak spark on a 34l?
Howmuch?!
- What Bike or Bikes Do You Own?: 34l
- Previously Owned Bikes: .
With my bike difficult to start,earthing the spark plug to the engine i'm not seeing a nice fat healthy blue spark. Changed the spark plug,no difference.The primary coil measured 20 ohms & 16 kilo ohms for the secondary.Is this about right?
If so, could it be the CDI? Is there any checks to prove this?
Re: Cause of a weak spark on a 34l?
All 3 of my 34L's show a pretty faint spark, not what you would normally expect but they all start first kick.
- Founding Member
Before you blame the spark...how does the bike run once you get it running?
If it keeps running without miss-fire and accelerates hard when required, then you should look elsewhere for the problem.
