Doghouses' 3YF Pup
King of Posting
King of Posting
Re: Doghouses' 3YF Pup
Post by xtzrick »
The oil in frame doesn't help, the heat melts the grease in the steering bearings.
Graphite grease helps them last longer & make sure your new lower bearing has the rubber seal fitted.
panterg
What Bike or Bikes Do You Own?: Yamaha T 600 RE
Previously Owned Bikes: Loads ! There's not enough room
Post by panterg »
Hi Will ,
Will you need to replace the carb body ? If so I have a carb that's been ultrasonic cleaned that I've been using for spares so if you only need the body it's yours for postage . Glenn
doghouse
What Bike or Bikes Do You Own?: xtz660 3YF
Xl650V
Previously Owned Bikes: Suzuki AP50, Yamaha FS1E, Kawasaki KE125, Honda CB125Twin, Yamaha DT175dx, Yamaha RD250LC, Yamaha XJ550, Honda VF500F2, Yamaha RD500LC, Honda CBR600, Yamaha FZ750, Suzuku GSX750ESD, Yamaha XJ900, Yamaha FJ100, Yamaha FJ1200, Honda CX 500 x 3, Kawasaki GT550, Honda NTV600, Aprilla Pegaso, Bmw 1100s, Yamaha XTZ660, and quite a few more than slip my memory
Post by doghouse »
Thanks for the carb offer.
If off down Halgeir's place on Saturday to relieve him of his goods and chattels so if he comes up short I will be in touch.
Everything can be fixed with the correct application of the right sized hammer.
xtrider
Post by xtrider »
I think a high temp wheel bearing grease will work in there and take the heat, I use it in my XL600 and it seems to stay without dripping.
That water pump that was creamed looks like some pumps I have seen around here when someone uses pure water or a very diluted antifreeze then it freezes, start the motor and all sorts of fun follows. In a bike I would imagine it just folded the fins over and ground them up with the ice chunks. That my guess :yess:
Hang in there with the parts, once your riding the cost won't matter , or as much.
doghouse
Xl650V
Post by doghouse »
Bottom bearing race gives it up to the mighty mig.
New gaitors, new inlet rubbers, new head races, new f sprocket lock washer...............another £100 bites the dust. :bigeek:
panterg
Post by panterg »
Right Oh Will - PM me if you need it . Glenn
doghouse
Xl650V
Post by doghouse »
The result of today's visit to Halgeir & Spencer
Hopefully that's it for the buying bits....now for the fixing bit.
doghouse
Xl650V
Post by doghouse »
Bearings off. Splodge of paint........Now the putting it all back together bit...................I forsee trouble ahead
socks
What Bike or Bikes Do You Own?: Honda VFR 750FV, Yamaha xt 600E 3AJ
Previously Owned Bikes: Honda's, superdream 250N, RS250, supersport CB750F,supersport CB400F
Suzuki TS250
Yamaha XT 600E 55W, IVJ
BMW K100
Post by socks »
:omg: I see bind weed,ivy,brambles and ground elder! loads of trouble if you like a clean lawn :biggrin:
And
You might want to clean that rust out from inside those fork clamps.
Nearly done!
Socks
doghouse
Xl650V
Post by doghouse »
socks wrote::omg:
That's not rust that's patina. :birdgrin:
