I also checked on the 1UY big bear part, he doesn't have one but its in stock in UK & it's a lot cheaper... 131 quid, know way of knowing if it's the same part though....
As for the main gear.. I wouldn't worry about it Dunc, I'm sure it'll be fine... if its not I've got one here you can have.... I had the same problem with Tenere 2, when I pressed the starter button the engine sounded like it was mincing gravel... all I did was fit a second hand one way bearing & it was ok...
As for all the help, you're welcome mate... you had the balls to get off your arse & get out there & were all secretly jealous as fuck that it's not us.... but if we were in the same position we'd be glad of the help too....
Just wish you'd come on here before you went & we'd have told you to fit a bloody kickstarter.....
