Help with Carbs for a 3aj
Airbox, Fuelpump, Carburettor
ferzz
What Bike or Bikes Do You Own?: XTZ 750 ADV-Ténéré RetroRaid
XTZ 660 original Marathon 1994 Motor-France
XT 600 Z replica Marathon 1990 Motor-France
MuZ Baghira original Paris-Dakar 1998 Nº 17 Marc Morales Team Challenge 95
Re: Help with Carbs for a 3aj
Post by ferzz » Mon Aug 18, 2014 10:50 pm
My German 3AJ also got an altitude compensator. I know more 3AJs in Germany got this.
Connect it to 17 on the left side of the primary carburetor:
And to 5 on the right side of the primary carburetor:
Pictures © www.XT600.de
Cheers Boris
-> RetroRaid - rally touring parts
000nicec
What Bike or Bikes Do You Own?: Yamaha Tenere XT600 3AJ
Previously Owned Bikes: Yamaha TZR 250'sssssss and Yamaha XT550
Post by 000nicec » Tue Aug 26, 2014 12:46 pm
Thanks a mill.
Hopefully that will help my Babee start easier.
I have no pipe on the number 5 and have blanked off number 17.
She used to start like a dream. Could stand for 2 weeks walk up to her pull the choke and within a crank or 2 she fired.
Now it takes a full battery charge to get her to start.
She eventually starts and dies starts and dies starts and dies.
Choke doesn't even seem to make a difference.
Well its trial and error........Especially when you not a boffin on these things.
But live and learn.
slywink:
Post by Mezo » Tue Aug 26, 2014 1:33 pm
000nicec wrote:Well its trial and error........Especially when you not a boffin on these things.
But live and learn. slywink:
Im no boffin either, i just stripped mine down & rebuilt it, to be honest i hate bloody carbs (so temperamental) :flogging:
Just keep plugging away (no pun intended) and you will become said boffin. :biggrin:
keny72
What Bike or Bikes Do You Own?: 1990 + 1989 Yamaha XT600Z Tenere, 1986 Yamaha IT200S, 1986 Honda VFR750F, 1995 + 1997 Honda CR125R, 1988 SUZUKI TS250X
Previously Owned Bikes: 1984 RG250W, 2000 Honda VFR800FI, 1991 Honda VFR750F, 1987 Honda VFR750F, 1987 Kawasaki GPZ500S, 1982 Suzuki GS500 Katana, 1982 Yamaha RD125LC, 1983 Yamaha DT125LC, 1985 KTM125GS x3, 1987 KTM125GS, 1989 KTM250GS, 1996 KTM400SC, 1994 Kawasaki KX125, 1996 Suzuki RM250, 2006 KTM250SX, 2002 CR125R
Post by keny72 » Sat Jan 23, 2016 9:14 pm
If I may come on to this topic. I have 2 3AJ:s, both 89-90 models and both imported from Germany. The one I first did buy has the altitude compensator, the second did not. As I had the carburetors apart today, yes both as I try to build a runner of 2 bikes, seem the first Tenere has the right carburetor as jets compare to the spec I found on that xt600.de site, but the second tenere has carburetor whit out the tube for the altitude compensator and jets like a 1988 3AJ aside main jet that was a 155 even should be a 165. I did put in the 160 from the other carbs. I got it running and feels like it runs rich. I have not check the needle posissions. Before the engine was like your, starts but dies. Only fault I found in the carbs was the small filter under the float needle was blocked by dirt, mainly paint flakes! Have to see if I check the needle clip positions or change all jets as needels to the 1990 spec as in the first teneres carb but use second teneres carb body. But first other things to do.....vibration issues....
Juan Pablo
What Bike or Bikes Do You Own?: Yamaha 1vj
Previously Owned Bikes: Puma 98, Honda atc 110, Honda xl125s
Post by Juan Pablo » Mon Sep 03, 2018 12:43 am
Hello, I am planning to trip to Bolivia this summer and run in the Argentinian and Bolivian "Altiplano", were altitude goes from 1500 to 3800 meters over the sea level.
I did a similar trip last year and my bike (Yamaha 1jv) run so bad over 2000 mts that I had to run most of the time at no more than 60km/h and no more than 1/4 throttle to avoid engine start to fail...
I should do something with my carbs, change jets perhaps, for 2000 metes altitude, but after seen this post I wonder if this altitude compensator could be adapted to my carbs. I see in mines that where this devise is connected, there are small bronze plugs. What I don't know is if I remove them, will I find the ducts completely machined or if they will be plugged.
Where these connection goes when they get into the carbs? what they do? they decrease the pressure in the float bowl making vacuum (this will affect both carbs) or they send more air to the air bleeder?
Is the altitude compensator devise easy to find? anyone one have one? what the cost? thank in advance for your comments. Regards
Jenik
What Bike or Bikes Do You Own?: XT600Z
Post by Jenik » Mon Sep 03, 2018 6:53 am
You need compensator and carburetor too, because regular 3AJ carb hasnt got the additional tubes for compensator. You should get 3DS carb or mode your current. Having 3DS and 3AJ carburators in my garage.
http://www.supertenere.cz
currently 3DS (3AJ), previously XTZ900 (95,25 Nm by 5484 rpm/min, 85,64 PS by 7271 rpm/min)
Post by jibber » Mon Sep 03, 2018 7:32 am
Juan Pablo
Post by Juan Pablo » Mon Sep 03, 2018 2:40 pm
Jenik, Jibber thanks for your soon answers, in the carbs that has the connections for compensation, where do the pipes go? Can you sea from some where in the carb or tha go to internal chanels? How the system works? It reduces the pressure in the float bowl? Regards
Jenik
Post by Jenik » Tue Sep 04, 2018 7:24 am
@google translator https://www.xt600.de/xt_stammbaum/model ... _88-91.htm
As the air gets thinner and thinner as the altitude increases, logically, the mixture becomes increasingly richer because the fuel content remains constant. To counter this, additional air ducts for the idle (17) and the partial load system (5) were installed in the primary carburettor of the Ténéré's 3AJ from '89 -91. If the air pressure decreases with increasing altitude, the barometer (air corrector) releases the air channels, the mixture becomes leaner. In the can I examined, the canals were opened at an air pressure of about 900 mbar, which corresponds to a height of about 1000 m above sea level.
Juan Pablo
Post by Juan Pablo » Tue Sep 04, 2018 12:00 pm
Thank Jenik! So both, 17 and 5 are air inlet...?
