Re: 34L001324 Restoration has started!
Aussiesven
What Bike or Bikes Do You Own?: XT 600 Tenere 34L 1983
Previously Owned Bikes: XT 600 Tenere; Xt 600 standard; XR 600; BMW R100GS
Post by Aussiesven » Sat Apr 27, 2013 6:00 am
Well, as mentioned the engine had to come out to check the barrel.
And it was like I expected, one of the older helicoil threads pulled out, so will give it to SERCO again and get him to try and fit a new thread/plug or whatever they need to do. The head certainly leaked as you can see, so it was time to have another go at it - one of the bolts was only hand tight... no wonder it leaked!
While I was at it, I also changed the main jet from #130 down to a #125, seemed to run a bit fat. What jet combination to others ride with? Got a #125 in the secondary carby, now also a #125 in the primary one - is that normal for Australia?
Once the barrel is beck from repair, I hope she will run a tad faster... let's wait and see.
Sven
Post by Mezo » Sat Apr 27, 2013 7:17 am
I have never been a fan of them helicoil thingys, my late father did this for a living for almost 40 years & never installed a single one, he said they are useless.
Better to mill out & weld a plug inside, then drill & tap again (as good as new).
Post by xtzrick » Sat Apr 27, 2013 1:05 pm
Mezo wrote:Better to mill out & weld a plug inside, then drill & tap again (as good as new).
Helicoils should be ok in steel but aren't long enough for alley, specially when torque is involved.
Zonda
What Bike or Bikes Do You Own?: 1991 XT600
1999 TRX 850
1969 CB450 (Honda)
1969 CL450 (Honda)
1970 CR450
Previously Owned Bikes: Wow, where do i start!!! well 1974 Honda XL 100 and then………arh my head hurts.
Post by Zonda » Sun May 05, 2013 1:58 pm
Helicoil's come in 5 lengths, for different applications, these are designed to be used for standard bolts, not for specialist bolts or for high torque bolts. A helicoil should never be used for cylinder head bolts, exhaust studs etc, for these areas, there a quite a few specialist inserts ie, "keysert" is a commonly recommended insert. The best repair will always be remove the damage, weld and re-tap, or replace the offending part :wink2:
Rod
You never get over the desire to do stupid things. You simply have
to overrule your stupid urges with an acquired sense of fear.
Aussiesven
Post by Aussiesven » Sat May 18, 2013 11:51 pm
Well gentlemen, you be glad to hear that the offending stud has been plugged and drilled and tapped. So the engine is all back together (even used genuine gaskets... after using some made in Asia kit last time) and running much nicer and is leak free.
Still not sure whether the reduction to the 125 jet was right, but I will ride like this for a while and see what the plug looks like.
So, all good to go! :oilleak:
Post by Mezo » Sun May 19, 2013 12:01 am
Nice one Sven, where did you buy your OEM gaskets & how much were they?
Aussiesven
Post by Aussiesven » Sun May 19, 2013 12:36 am
Never cheap those things from the Yamaha dealer: They were both about $80 each for the head and the barrel gasket.
Post by Mezo » Sun May 19, 2013 1:26 am
Aussiesven wrote:Never cheap those things from the Yamaha dealer: They were both about $80 each for the head and the barrel gasket.
Well never cheap from an Australian Yamaha dealer Sven, if you got them from Partzilla the head gasket would be $45.00 & the base on a mere $9.50
wmoncrieff
What Bike or Bikes Do You Own?: 1983 XT600 TENERE in sad condition! 1987 JDM VT250F [sold]
Previously Owned Bikes: Last count, about thirty...........
Post by wmoncrieff » Sun May 19, 2013 5:37 am
Good to hear it's back together again Sven :dance: Interesting to see how it runs with the different jetting? Is your exhaust system stock or modified?
Cheers Will.
Aussiesven
Post by Aussiesven » Sun Jun 02, 2013 4:14 am
Exhaust is a "standard" SEBRING aftermarket exhaust that was available in the 80s in Germany... so that's the one the bike always had on and ran well with for years. was thinking to hunt for an original one day as I like the sound better...
Mezo, agree elsewhere they might be cheaper, but was in the usual... "can't be bothered and go next door to the Yamaha dealer" mood as I wanted to get it done, so you pay more, but hey it's only money, isn't it? :biggrin:
Sven
