3AJ rebuild ... at last
welshlamb
What Bike or Bikes Do You Own?: Laverda 1000,Yamaha FJ1200
Previously Owned Bikes: Ktm 990 (X2), Bimota DB2, Laverda Corsa, TDM850, FZ750, XS750, GS750, CB550, CB250
Re: 3AJ rebuild ... at last
Post by welshlamb » Tue Mar 27, 2018 7:07 pm
Mezo wrote:
Sun Mar 18, 2018 8:13 pm
That swingarm axle is too short, looks like its been hacksawed off :bigeek:
I dont have the measurement of the axle possibly another member has one out of the bike they could mesure?
Replacement part in pic below alongside the one that came with bike. Correct 3AJ item 10mm longer. Will clean up and add to the Items to be zinc plated box.
welshlamb
Rear brake shims.
Post by welshlamb » Tue Mar 27, 2018 7:15 pm
What is the purpose of the rear brake 'shims' asI can only see them fitted to the rear? Heat, anti rattle, ??. Do you really need them ie is this another item to add to my 'purchases list??
ALSO... is anyone having any faraway blue powder coating done. PO had the lower engine bracket on my bike coated black and it just doesn't look right to me. (see pics page 1) My coater is not interested in a single item so might be easier to join in with someone else if they have anything going through??
Engine handed over to Kev Thomas for an initial look see and diagnosis of required extent of rebuild. Nice guy and happy to give me some advice on various rebuild issues. Should get some feedback from him next month and in meantime plenty to keep me happy (and purchasing!!) with the running gear and rest of issues.
Post by Mezo » Tue Mar 27, 2018 7:41 pm
Did you ask Kev if he was powder coating blue anytime soon? he's just finished one a few weeks ago, i know Geoff is stripping/rebuilding a blue 3AJ as we speak, not sure if he's doing another white frame though?
As for the anti squeal shims, ive just used a blob of copperslip on all my brake pads.
welshlamb
Post by welshlamb » Wed Mar 28, 2018 10:29 pm
Doh!! Missed the blindingly obvious first point of call there! Will give him a call. Cheers
welshlamb
Post by welshlamb » Mon May 14, 2018 8:36 pm
No luck re the Faraway blue with Kev so anyone out there having some done I'm still interested.
In any case progress has been a bit slow as the recent good weather has meant catch up time with house exterior and garden DIY. (ongoing!)
Good news has been
-sourced correct swinging arm spindle from ebay. Just needs zinc replating with some other items (hopefully next week)
-secured an Arrow exhaust to complement the GPR headers . Decided to coat black as I I know how hard it is keeping the stainless looking new and the black matches the original colour scheme.
- Brake calipers have been cleaned, vapour blasted and painted so just need to rebuild with all new components (which I have)
Bad news
- main fairing has one of the four mounting lugs missing and has had some repairs over the years. Need to look at how bad
-Front mudguard bolt hole lugs broken both sides (but badly mended) . Very little material around the holes so not surprising. May see if part can be plastic welded and then bond a metal plate for reinforcement to the rear
-Initial strip down and diagnosis from Kev Thomas worse than I hoped for. :fan: It needs rebore & piston, oil pump and screen plus the almost inevitable 5th gears. Add in all the seals , gaskets, fasteners , repaint etc etc and total about 50% above my budget. Yes I could do it cheaper with non OE parts and my own labour but I know my limits. Would rather have someone do it that has proven track record and if I ever do have to sell the bike it should hopefully stand me in good stead.
Having stewed on that one overnight and given Kev the green light to go ahead (just before he sets off to Morocco for 2 week!) I also agreed to a 640 kit (it needed new barrel and piston anyway) and a mild head job. Any extra oomph will be much appreciated moving my 16st (without gear) body around.
-Noted that the rubber fork gaiters are falling apart in the folds of the bellows, so will need new ones
Build has actually gone backwards in last few days as I've dismantled the part assembled rolling chassis to refinish some parts and for peace of mind re assembly. As stated above, the fact its my first XT and I didn't strip it down are big minuses when putting it back together again. NOTE TO GEOFF...please post lots of pics for your current rebuild :pleasesir: as unfortunately the Shite Bucket scam has robbed me of yr previous illustrated restorations which would have been a great help to me!
Will post some photos soon of the bits I have so far (and slow progress) in the meantime ..
where best to get fork gaiters, gear lever (any alternatives to the always bent OE part?), yellow disc guard?
Post by Mezo » Mon May 14, 2018 9:06 pm
You can still see all of Geoff`s pics by going direct to his Shitbucket account HERE once your rhere just look on the left side at his albums. Its only the third party hosting that was blocked
Same goes for my 3AJ Rebuild plus other Tenere related pics.
welshlamb
Post by welshlamb » Tue May 15, 2018 12:42 pm
Heaps of bedtime browsing for me then! :thanks:
welshlamb
Post by welshlamb » Tue May 15, 2018 6:21 pm
"where best to get fork gaiters, gear lever (any alternatives to the always bent OE part?), yellow disc guard FRONT BRAKE DISC. The only 'good' used discs I can see are in USA. What new ones have folks fitted and would recommend?
Post by Mezo » Tue May 15, 2018 8:35 pm
There is a thread on this subject as its a commonly asked question "The Great Fork Boot Debate" my choice was Airete brand (if you can find a supplier).
Post by GeoffD » Tue May 15, 2018 10:46 pm
I've used EBC discs a couple of times, available from most online bike spares places, or even your dealer...
