Bigiains 55w
Re: Bigiains 55w
Post by Mezo » Thu Oct 20, 2016 7:33 pm
bigiain wrote:Does anybody know how to get the tank/seat Gap a bit better.l was thinking heat up the base with a heat gun and try to bend it forward a wee bit. Or glue some kind of lug onto the back of the tank and a slot on the seat that slides into it.
Hey Ian, bikes looking fantastic :dance:
Yep the seat gap is a common issue on 34L`s & 55W`s (its been talked about on here before) Dave Lambeth thinks its the foam getting soft with age? i think he is or was going to make replacement foam? seems you have time before its going to be used i would bring it indoors & flip it over and put some weights on the back, place it near a radiator or just in a warm room & leave it for a months or two, it will stretch that new cover.
Try that first before going radical with heat guns & other stuff, just allow that material to stretch nice & slowly, enter "seat gap" in the search box (top right). :thumb:
bigiain
What Bike or Bikes Do You Own?: 55w tenere in bits Honda xr 650r
Previously Owned Bikes: Suzuki er 125, Yamaha rd 350(still got a sore knee from crashing it)
Bombardier 250, Honda xl 250, Honda xr 600,Suzuki Dr 600
Xt600, Yamaha fz 600, s10 750, Kawasaki zx9r,Honda cr 500
Yamaha yz 490, Kawasaki kx 500, Yamaha xt 500 ( sold it for £200 what a
Tosser)
Re: Bigiains 55w
Post by bigiain » Wed Dec 07, 2016 12:15 pm
Help! I've split the cases. First time I've done this.any help appreciated.what will I do next,replace all bearings and oil seals
The engine number is 43f i think it's been split before.it already has a 3aj oil pump. The magneto came off easily with a home made puller.
Inside of case is slightly scored under kickstart shaft about 1mm deep
The gudgeon pin slips into the conrod easily there is a bit of diagonal play in it.is there a way of measuring if it's okThe big end has no up and down play just a little side to side how can I check this.
Slight pitting on the top of the gear teeth what do you think
Been working hard sold xr 650 bought myself a Christmas present . First brand new bike I've ever had. The weather here is so shitty all I have done is sit on it and go brmmm brmmmm :nordie:
Re: Bigiains 55w
Post by jibber » Wed Dec 07, 2016 2:02 pm
I was surprised to see what those 928's are fetching now......
difficult to see any pitting on those gears........
bigiain
Tosser)
Re: Bigiains 55w
Post by bigiain » Wed Dec 07, 2016 2:26 pm
Hello jibber it's my sons 928 he has kindly left in my garage for 8 years for me to trip over. It's slowly appreciating,we bought it when nobody wanted them. Will try and take better photos of gears to me pitting looks minimal but I don't want to go this far in without making it perfect.
Got most of the bearings out how do I get these two? Also how do I get the camchain sprocket off the crankshaft to let me get the big bearing off
Re: Bigiains 55w
Post by jibber » Wed Dec 07, 2016 4:43 pm
Cheapest way of removing those two would be to heat up the casing, say about 100 degrees, and slap it down onto a firm but softish surface, a piece of mdf on the floor or the like, proper way would be to use a blind bearing puller. Cam chain drive is a bit of a bitch , you will need a puller and some decent heat applied while applying pressure with the puller.
Re: Bigiains 55w
Post by Mezo » Wed Dec 07, 2016 7:54 pm
As Jibber says & has been posted on here, warm the case is wifeys oven & then bang down on a flat surface.
Those gears look in remarkable condtion, almost certain this engine been apart before (hence why the flywheel came off easy) :wink2:
Re: Bigiains 55w
Post by Mezo » Wed Dec 07, 2016 8:00 pm
jibber wrote:I was surprised to see what those 928's are fetching now.......
I think it was on Top Gear or Fith Gear & then people realised what a car it is, powerfull V8 & handles brilliant, an overlooked luxury GT.
bigiain
Tosser)
Re: Bigiains 55w
Post by bigiain » Thu Dec 08, 2016 10:05 am
Luckily the snap on van was passing by last night so I flagged him down and £400 later was the proud owner of this precision
Bespoke bearing puller :lol:
It may have a slight design flaw, the bearings came out so easily the end of the rod nearly took my fuckin eye out!
Reading other posts I think my best crankshaft option is to get a new conrod,crank pin and big end bearing from holland,
For a 43 f engine then buy main bearings locally. Take it to a machine shop and get it pressed off/on.
Either that or does anyone know who would do an exchange crankshaft.
Cheers Iain
Re: Bigiains 55w
Post by Mezo » Thu Dec 08, 2016 10:10 am
bigiain wrote:Image
Mezo :biggrin:
bigiain
Tosser)
Re: Bigiains 55w
Post by bigiain » Sun Jan 08, 2017 1:09 pm
FFS 3 :yay:
