3AJ oil cooler relocation?
keny72
What Bike or Bikes Do You Own?: 1990 + 1989 Yamaha XT600Z Tenere, 1986 Yamaha IT200S, 1986 Honda VFR750F, 1995 + 1997 Honda CR125R, 1988 SUZUKI TS250X
Previously Owned Bikes: 1984 RG250W, 2000 Honda VFR800FI, 1991 Honda VFR750F, 1987 Honda VFR750F, 1987 Kawasaki GPZ500S, 1982 Suzuki GS500 Katana, 1982 Yamaha RD125LC, 1983 Yamaha DT125LC, 1985 KTM125GS x3, 1987 KTM125GS, 1989 KTM250GS, 1996 KTM400SC, 1994 Kawasaki KX125, 1996 Suzuki RM250, 2006 KTM250SX, 2002 CR125R
Post by keny72 » Fri Mar 16, 2018 8:13 pm
So I wonder if anyone has relocated the oil cooler on a 3AJ? (or 1VJ for that matter)
I been looking at colors old Dakar Teneres has used, and noticed the 86 XT600 Dakar bike has the oil cooler under the headlight
Ok, it don´t have the twin headlight of the the 3AJ, but I started to think if, for example a Honda VFR750 -86-89 oil cooler could be fit hanging below the front faring.... :book:
And is it big enough? :fireball:
Toughts are welcome
:tenere:
Re: 3AJ oil cooler relocation?
Post by Mezo » Fri Mar 16, 2018 8:36 pm
Which oil cooler are you talking about? the short one on the MK1 3AJ or the longer one on the MK2? (1990) and do you need to relocate it? the one in the picture is not a Yamaha item (on the bike).
One member on here was playing with the idea of a cooler from a Citroen 2CV, but i dont think its necessary, you could put two of the longer 3AJ items side by side if you welded lugs to the frame.
You can buy generic OIL COOLERS any size you want.
welshlamb
What Bike or Bikes Do You Own?: Laverda 1000,Yamaha FJ1200
Previously Owned Bikes: Ktm 990 (X2), Bimota DB2, Laverda Corsa, TDM850, FZ750, XS750, GS750, CB550, CB250
Post by welshlamb » Fri Mar 16, 2018 10:41 pm
What are the respective length of my 1 and Mk2 3AJ oil coolers. Think my bike is a Mk1 but seems to have a long cooler on it.
Interestingly I noticed that the DT125R Tenere (2 stroke) has a fairing very similar to that on the 86 works XT600! Maybe it would fit!
BMurr
What Bike or Bikes Do You Own?: James autocycle
BMW R100GS
Hoping to acquire a 43f
Previously Owned Bikes: MTX126, Xt600 43F, Kawa GT550,750,GTR1000, BMW R100GS (x2)
Post by BMurr » Sat Mar 17, 2018 8:21 pm
Would it be possible to mount it to the front frame down tube, this is the location used on the old BMW gs bikes and it works well, obviously a need to fabricate a bracket for that job on an XT but is there any reason why it wouldn't work, plenty fresh air coming in there and front fender should be keeping most of the muck off?
keny72
Post by keny72 » Fri Jun 08, 2018 5:25 pm
The oil cooler in the picture I posted is a 1986-87 Honda VFR750F RC24 oil cooler (its about 10 cm shorter than the long 3AJ oil cooler, 25cm vs 35cm), that is hanging below the headlight on the VFR as orginal place. I don´t need to relocated the oil cooler, but as the long one I have on my 89/90 are a overkill for where I live most of the year, and the location the 3AJ oil cooler has (1VJ for that matter) is kind of puor, as it`s in way of the air flow for the cylinder, I think a relocation would not be a bad idea. But have to see...life is a bit of :fan: right now.....
