Stiffer front suspension
bum bum
What Bike or Bikes Do You Own?: xtz660, tt350
Post by bum bum » Sun Sep 10, 2017 12:13 am
I'm not an advanced rider by any measure but I can tell the front is unnervingly soft and since im replacing those rubber protectors anyway I'm gonna replace the oil and then why not replace the springs also? I mean, you're riding in loose sand or braking on tarmac and the front just dives, do you change the springs or just the oil?
Red_Lion
What Bike or Bikes Do You Own?: XTZ660 3yf
Re: Stiffer front suspension
Post by Red_Lion » Thu Oct 19, 2017 2:47 pm
Springs are weakened over time. If they are already 10 years old, it is better to change. I advise the progressive springs.
Also I advise you to check the bushings (two rings - bearing) in the plug - they can be worn out.
bum bum
Post by bum bum » Tue Nov 07, 2017 9:53 pm
Thanks.
You mean these bearings http://www.wemoto.com/bikes/yamaha/xtz_ ... balls_usa/ ?
Not familiar with the terminology (the plug?)
blackshark
What Bike or Bikes Do You Own?: 39E Tenere, 36A TT600, 1VJ Tenere, Honda CB900 Boldor, Suzuki T350, M63 Ural
Previously Owned Bikes: numerous
Post by blackshark » Wed Nov 15, 2017 10:51 pm
If you replace the springs, make sure you get springs to suit your weight.
