New regulator, low voltage still
bum bum
What Bike or Bikes Do You Own?: xtz660, tt350
Post by bum bum » Mon Aug 07, 2017 9:55 pm
On the latest long trip I had it was evident that the battery was barely charging at all so I got a new regulator and installed that but the multimeter read the same as before so it must be something else.
I got 12.70 when fired up and like 13.20V with a little gas.
Already tested the battery in another bike and was OK, close to 14V.
Re: New regulator, low voltage still
Post by ActionManMelb » Tue Aug 08, 2017 2:49 pm
Make sure regulator has a solid connection to the frame and the neg. terminal of the battery.
Run additional wires if you have to and scrape the contact area for good connection.
